![:(](http://www.vx220.org.uk/forums/public/style_emoticons/default/sad.png)
![:o](http://www.vx220.org.uk/forums/public/style_emoticons/default/ohmy.png)
![:)](http://www.vx220.org.uk/forums/public/style_emoticons/default/smile.png)
![:groupjump:](http://www.vx220.org.uk/forums/public/style_emoticons/default/jump.gif)
Posted 30 August 2004 - 09:32 PM
Posted 30 August 2004 - 09:33 PM
And a picture of the mounting.
Posted 31 August 2004 - 07:40 AM
Posted 31 August 2004 - 07:54 AM
Posted 31 August 2004 - 08:00 AM
Cost ?Why not just get an exhaust which doesn't set off the EML?
Posted 31 August 2004 - 08:24 AM
Fair point but I don't understand the desire to potentially screw a £1000 ECU by bypassing one of its measurement functions designed in part to save the engineCost ?Why not just get an exhaust which doesn't set off the EML?
Posted 31 August 2004 - 03:49 PM
Have you?Has anybody had problems with with british approved 200 cell cats?
Posted 31 August 2004 - 03:57 PM
I can only speak for Milltek, but the answer is no, none.Has anybody had problems with with british approved 200 cell cats?
Posted 31 August 2004 - 03:59 PM
First sign of madness.Have you?Has anybody had problems with with british approved 200 cell cats?
Posted 31 August 2004 - 04:09 PM
Pipo was discussing this in Lux. I think it's availability of parts in Belgium.Why not just get an exhaust which doesn't set off the EML?
Posted 31 August 2004 - 10:13 PM
Posted 01 September 2004 - 06:39 AM
InterestingThe 2nd Lambda probe is only there to check the good function of the cat. It has nothing to do with the rest of the engine management. .
Posted 01 September 2004 - 07:01 AM
that was me...I mentionned my solution here in this forum because I remembered to have read some time ago about someone who had mounted a sportcat and had the problem of the EML coming on every now and then. He bought an electronic device in the USA (about 50 £) which should have cured his problem, but it didn't work.
Edited by Ricky2772, 01 September 2004 - 07:04 AM.
Posted 01 September 2004 - 08:05 AM
Posted 01 September 2004 - 02:40 PM
I've seen this before on Hondas but a lot less complicated. When they were decatted the single sensor wire had to be cut and earthed and this kept the check engine light off. All it did was check the temperature of the cat - too hot (as damaged or empty cats get) and the light came on. It sounds like the VX one is more complicated and looks for a specific range instead while having nothing to do with the actual fuel trim?Interesting
, would vauxhall use it just to flag up a light to tell you the cat is stuffed?
Edited by nonterraquous, 01 September 2004 - 02:40 PM.
Posted 01 September 2004 - 09:08 PM
Posted 02 September 2004 - 07:28 AM
I know at least 3 other belgians without cat:As far as I know I’m the only Belgian Speedster driving an exhaust with no cats at all.
Posted 02 September 2004 - 07:37 AM
Posted 04 September 2004 - 03:28 PM
