Is there currently an aftermarket wheel picture thread on the forum? If so, can someone point me in the right direction? If not, show me your wheels!
Wheels Thread
Posted 08 August 2014 - 04:21 PM
Posted 08 August 2014 - 05:47 PM
Ats dtc wheels
Posted 09 August 2014 - 08:08 AM
Compomotive MO 5 spoke
Posted 10 August 2014 - 11:37 AM
Posted 10 August 2014 - 11:49 AM
Posted 10 August 2014 - 11:50 AM
You don't have that much freedom in wheels.
Most above samples have been custom specced for the VX. (offset etc)
Most common are 16/17 or 17/17.
Too much to explain about all wheels.
Just pick what you like and we can tell you pros and cons.
Edited by smiley, 10 August 2014 - 11:50 AM.
Posted 11 August 2014 - 08:07 AM
The Compomotive sizes are :
[color=#000000;][font="arial, helvetica, sans-serif;"]Front et20 7x17[/color][/font]
[color=#000000;][font="arial, helvetica, sans-serif;"]Rear et30 8x17[/color][/font]
[color=#000000;][font="arial, helvetica, sans-serif;"]Tyres are:[/color][/font]
[color=#000000;][font="arial, helvetica, sans-serif;"]Front [/color][/font]205/45/17
Rear are currently standard size, but need some new tyres soon, and will go for 235/45/17.
Fit great, only get very slight rubbing on fronts on full lock.
Edited by .Adam., 11 August 2014 - 08:09 AM.
Posted 11 August 2014 - 08:16 AM
Posted 11 August 2014 - 08:46 AM
TD Pro Race 1.2 7x16 ET20 / 8x17 ET36.
205/50-16" front, 235/40-17" rear with no rubbing what so ever.
Posted 11 August 2014 - 08:52 AM
Interesting that the Speed lines are so heavy, is it the thick spoke design or material used?Weights are a factor too... Lightest OZ Superturismo 16/17 Team Dynamics 16/17 OEM Wheels ATS DTC XYZ ABC 17/17 VXR Speedlines 16/17 Heaviest
Posted 11 August 2014 - 09:15 AM
Posted 11 August 2014 - 09:26 AM
What benefit is that? Not like the VX is a heavy car and needs strong wheels? On the TVR maybe, as their wheels seem to be made of cheeseHeaviest but probably the strongest
Posted 11 August 2014 - 09:28 AM
Not neccesarily. It'd depend on the grade of alloy, the shape etc. Too many factors to be accurate.
Posted 11 August 2014 - 09:30 AM
Depending in tyre choice you can undo expensive lightweight wheels weight saving very easy.
Posted 11 August 2014 - 09:32 AM
It's a good job they are because you're sh!t out of luck if you need to get a replacement wheel. Same with the OZ's.What benefit is that? Not like the VX is a heavy car and needs strong wheels? On the TVR maybe, as their wheels seem to be made of cheeseHeaviest but probably the strongest
Posted 11 August 2014 - 09:51 AM
