Wiring Help
9 replies to this topic
#1 sworks
sworks
  • 1,566 posts
Posted 09 August 2014 - 11:43 AM
Could someone point me in the right direction for the wire I need to splice into to connect a switch for the relay on the water pump for the charge cooler
Thanks
Chris
#2 fezzasus
Posted 09 August 2014 - 12:06 PM
white/purple wire.
#3 sworks
sworks
  • 1,566 posts
Posted 09 August 2014 - 12:15 PM
Cheers tom. Also, wiring in tmap, obd manual says pin 1, 2 and 3. My map sensor has a, b, c. Is it as obvious as I think it is a=1 and so on? The IAT has no markings on that I can see. How would I distinguish pin 1 from 2 Thanks
#4 fezzasus
Posted 09 August 2014 - 12:22 PM
I think your plug for the TMAP should have numbers, rather than the sensor
in terms of wiring the IAT leads into the TMAP, you need to check the wires for a common ground (use a multi meter) on the IAT and MAP, they both combine into pin 1, therefore process of elimination leaves the remaining IAT lead as pin 2
#5 sworks
sworks
  • 1,566 posts
Posted 09 August 2014 - 12:30 PM
Thanks. No ecu or battery in the car at the moment, so guess that will have to wait. Thanks
#6 fezzasus
Posted 09 August 2014 - 12:32 PM
You don't need them in to check it, power doesn't run through the ground, just set the multi meter to a resistance measurement (1k for example) and test for a low resistance between the two wires, that means they're connected and therefore share the same ground.
#7 sworks
sworks
  • 1,566 posts
Posted 09 August 2014 - 02:28 PM
Ah ok, cheers mate. I sometimes wonder that if I had half a brain I'd be dangerous!!
#8 Exmantaa
Posted 09 August 2014 - 05:57 PM
The sensor wires rub through the ecu connector to ground, so you need to connect the ecu to check this! a,b,c = 1,2,3...
#9 Exmantaa
Posted 09 August 2014 - 06:00 PM
Water pump > use pin 8; fuel pump steering wire. White/purple on most. (That thick wire is pin 1, main 12v feed to ecu, so count from there)
#10 sworks
sworks
  • 1,566 posts
Posted 11 August 2014 - 08:03 PM
Thank you thumbsup
