Tried the pressed out style of mesh fitting and promptly gave up trying to get it perfect all the way around. Couldn't be bothered with creating any recessed lips or anything as I didn't want the expense of a re-spray so just opted for the set back painted cut edge which I actually think looks OK anyway.
Not sure if I'm going to bother but it would be simple enough to install two additional parking sensors somewhere here to improve on my semi stealth number plate ones.
Secondly moving up the clam to something I don't think anyone has really done before, my boot mod.
First job was to remove the black plastic number plate light covers that are bonded onto the inside of the clam. This was a real PITA and took some time as you need to be careful not to be to rough for risking damage.
Eventually got them out the way and installed new slim LED ones.
Next was the point of no return, the main hole cutting.
Ran with it blocked up for a while and it was funny seeing peoples reactions in the rear view mirror to this!
Dibond type composite sheet used to strengthen the hole and act as a recessed frame for the grilles etc.
