Crashed The Vx
53 replies to this topic
#1 jacobw94
jacobw94
  • 363 posts
Posted 21 August 2014 - 10:36 PM
Went for a pootle about today and ended up a few feet from the road in a hedge:
I'm fine, and the car seems to be a lot better than it could have been. The only damage I can see is to the front Clam, under the drivers side sill, to the wheels+Tyres and to the crashbox surround(?)
Just trying to weigh up my options for the front clam, was wondering if I could get a lower half clam to replace mine, and then repair the damage to the upper half? And if not what would my best bet be? I see Lotus hardtops do a Front clam for the VX220 for £899. And what I would need to do about the crashbox surround(?) or where I could get one from? Thanks in advance
#2 myles
myles
    Sausagefest
  • 2,084 posts
Posted 21 August 2014 - 10:46 PM
Damn. Not much more of a constructive nature to add but hope you sort it cheaply.
#3 Nelly Vx
Nelly Vx
    3/3 Of a Queen
  • 5,928 posts
Posted 21 August 2014 - 10:49 PM
Sorry to see this Jacob :-( , good to hear you are unhurt . Hope you can get it sorted with out too much hassle :grouphug:
#4 Claws
Claws
    Stage FA NA FTW!
  • 5,246 posts
  • Interests:Daft plastic cars
Posted 21 August 2014 - 10:50 PM
:yeahthat:
#5 ollie2007
ollie2007
    Sir drink a lot
  • 1,308 posts
  • Location:Inside my turbo its a beautiful place you know
  • Interests:Working on the VX ,alcohol, drunk street fighting with Rudy. life doesn't get much better than that
Posted 21 August 2014 - 10:53 PM
Fix the rad surround with fibreglass it is a p*ss easy fix, plenty of broken cheap front clams to buy the lower half and fix, I reckon about £450 damage without the headlight, hopefully the light is ok. Don't feel down these cars are easy to fix as long as there is no chassis damage.
#6 ollie2007
ollie2007
    Sir drink a lot
  • 1,308 posts
Posted 21 August 2014 - 10:55 PM
Correction just saw last pic, the reps ray will be about £500 depending on who does it, so all in with out light about £950
#7 jacobw94
jacobw94
  • 363 posts
Posted 21 August 2014 - 11:01 PM
Thanks, that doesn't sound bad at all. Headlight is miraculously fine, found it in the hedge about 4 inches in front of the car, will just need the cables re attaching
#8 Foxy
Foxy
    I love Nev
  • 10,743 posts
Posted 21 August 2014 - 11:25 PM
Sorry to hear this mate :(
#9 Hark
Hark
  • 3,443 posts
Posted 21 August 2014 - 11:52 PM
Blimey bet that was a tight arse moment. Glad you're ok.
#10 Andy_VX
Andy_VX
  • 2,050 posts
  • Interests:Cars, Boats, F1, Cycling, Home Cinema, Music.
Posted 22 August 2014 - 02:37 AM
Glad you're ok, what happened exactly?
The car doesn't look too bad but i probably wouldn't bother repairing that clam. I'd buy one from lotus hard tops and do the job properly. Joining clams is never ideal and yours looks like it will be significantly weakened. The radiator surround can be repaired but the extent of the damage will become much clearer once you've removed the clam. Have a good look at the crash box for any damage and the chassis around the wishbones etc. looks to be only cosmetic so should be an easy fix!
#11 Stevie Dubyah
Stevie Dubyah
  • 1,534 posts
  • Interests:Invasive Operations
Posted 22 August 2014 - 06:07 AM
Sorry to see this. Glad you're OK. Culling season seems to have kicked in early this year.
#12 Rudy
Rudy
    ZZZzzzzz.....
  • 3,375 posts
Posted 22 August 2014 - 06:27 AM
Good to hear your okay, it's just a car and is fixable. As per Andy's comment, how did it happen? Driver error, part failure etc?
#13 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 22 August 2014 - 06:30 AM
Don't fully agree here..
Clam is fully repairable by a good fiberglass firm.
Just a new lower half, the rad surround, as per one of the above posts..patch it.
Lucky with the light
You can do that kind of damage going off track
#14 TazN
TazN
  • 2,931 posts
Posted 22 August 2014 - 06:31 AM
Radiator surround can be easily fixed, especially as it doesn't look like you've lost any parts from it.
Front clam could be repaired with a lower section and then any damage to the upper section, however I'd think it wouldn't be that far off a new front clam from Jonny.
Glad you are ok and car is relatively undamaged. just make sure you take front clam off and inspect the crashbox and the chassis It will be worth looking at possibly going through insurance as I would expect it to cost ~£1.5-£2k with a new clam.
#15 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 22 August 2014 - 06:34 AM
Looks like crash box may have just taken a glance. Rad surrounds can be repaired no problem. You can get a lower section but it will cost you more in prep and you'll be replacing it in 6 months as per Andy's post above. You'll be back on the road for £1300 if you saved the headlight.
#16 Stevie Dubyah
Stevie Dubyah
  • 1,534 posts
Posted 22 August 2014 - 06:38 AM
....and your underpants clash horribly with the top you are wearing...
#17 Claws
Claws
    Stage FA NA FTW!
  • 5,246 posts
Posted 22 August 2014 - 06:40 AM
Buy a Lottery ticket! :lol:
#18 Nev
Posted 22 August 2014 - 06:59 AM
Ooops, easily done, good luck with the repair.
#19 jacobw94
jacobw94
  • 363 posts
Posted 22 August 2014 - 08:26 AM
What I went into was mostly soft, from what I can see the chassis and crash box are undamaged. I was going round a right hand bend when I hit a patch of water, the back end stepped out and I corrected left. The car gripped and it sent me into the kerb on the left, both my wheels hit the kerb and this bounced me to the right of the road, where I hit the kerb and went over it, car carried on 4 or 5 feet before I was stopped by a hedge. Can anyone recommend a good fibreglass repair shop? I'm in the mansfield area. Going to take wheels off now and see if tyres reinflate
#20 jacobw94
jacobw94
  • 363 posts
Posted 22 August 2014 - 08:27 AM
Those underpants are not mine! They belong to Stefcaz94!
