Posted 11 September 2014 - 07:25 PM
Posted 11 September 2014 - 07:30 PM
Posted 11 September 2014 - 08:31 PM
Seems to be happing more and more but what Chris said.I've just had the same Changed primary lambda everything ok
Posted 11 September 2014 - 08:45 PM
Posted 11 September 2014 - 08:48 PM
Hair dryers that will blow everything away.That's the trouble owning an NA with bolted on hair dryers,
Posted 11 September 2014 - 09:33 PM
Not too bothered about it tbh, but it's odd that it just started, and then doesn't happen all the time.Seems to be happing more and more but what Chris said.I've just had the same Changed primary lambda everything ok
Posted 11 September 2014 - 09:34 PM
And you can fck right off PaulThat's the trouble owning an NA with bolted on hair dryers,
Posted 11 September 2014 - 09:35 PM
It also messes with your fuel trims In my case it was using 25% more fuelNot too bothered about it tbh, but it's odd that it just started, and then doesn't happen all the time.Seems to be happing more and more but what Chris said.I've just had the same Changed primary lambda everything ok
Posted 11 September 2014 - 10:13 PM
Posted 12 September 2014 - 05:33 AM
Posted 12 September 2014 - 06:49 AM
Yup, it is seriously drinking fuel. Sounds the same issue as you had, will check and change anyway. ThanksIt also messes with your fuel trims In my case it was using 25% more fuelNot too bothered about it tbh, but it's odd that it just started, and then doesn't happen all the time.Seems to be happing more and more but what Chris said.I've just had the same Changed primary lambda everything ok
Posted 12 September 2014 - 05:12 PM
Also tagged with one or more of these keywords: fan
The Market Place →
Group Buy Room →
New T7Design Heater For The Vx220Started by 'Buchos' , 05 Mar 2017 heater, fan, hot, cold, air and 5 more... |
General Discussion →
VX220 Discussion →
Radiator Fan Fallen Off!Started by vxtmike , 06 Jul 2015 radiator fan, rad, fan, radiator |
