Z22Se -> Z20Let
engine; motor; swap; turbo
29 replies to this topic
#1 Bandris11
Bandris11
  • 67 posts
Posted 28 September 2014 - 12:08 PM
I am seriously thinking of buying a replacement Z20LET motor into my Z22SE NA.
Anyone who has such knowledge or experience, would you share the weak points or obstacles on the long way of motorswap please?
I would get a shorter final gear ratio, lighter flywheel, new clutch for sure to get a more optimal setting, but what else is needed in your opinion? (the Z20LET comes from an Astra with all accessories, but I am sure I need a new cable harness, intercooler, routing, etc...)
Opinions please! Thank you.
#2 CHILL Gone DUTCH
Posted 28 September 2014 - 12:15 PM
You could alway turbo charged the z22se
#3 fiveoclock
fiveoclock
  • 9,453 posts
Posted 28 September 2014 - 12:40 PM
Think you'll need a turbo rear clam or cut the boot out on yours
#4 -Dab-of-Oppo-
-Dab-of-Oppo-
    Cuntpuffin
  • 3,646 posts
Posted 28 September 2014 - 01:00 PM
Unless you are really attached to your current car and/or already have substantial mods surely it would be cheaper or at least far easier just to sell up and buy a VXT?
Edited by -Dab-of-Oppo-, 28 September 2014 - 01:02 PM.
#5 fezzasus
Posted 28 September 2014 - 01:47 PM
Probably not many to choose from in Hungary
Edited by fezzasus, 28 September 2014 - 01:47 PM.
#6 Duncan VXR
Duncan VXR
  • 5,278 posts
Posted 28 September 2014 - 01:49 PM
The cut is very very minor and to boot inner lip for vent section to clear top hat / pipe clearance. Also some holes for turbo chimney I did a astra vxr and 6 speed box on my standalone conversion. Saves the pain of retro fitting turbo loom and better starting point over older turbo lump Stanalone gives that 1:1 tb / pedal ratio and linear power delivery of the n/a with proper power and torque ;) DG
#7 Bandris11
Bandris11
  • 67 posts
Posted 28 September 2014 - 07:29 PM
Thanks for the comments, actually Fezzaus is right about VXr´s in Hungary... THere are 0 for sale.
I was also thinking of supercharging the NA, but the getting a Z20LET seems to be cheaper, while saving the original engine as well...
Keep up shooting your comments at me please as I would like to be as prepared for the worst as possible :)
#8 slindborg
Posted 28 September 2014 - 07:35 PM
You'll need the gearbox swapping completely as the starter is on the otherside
#9 peteslag
peteslag
  • 919 posts
Posted 28 September 2014 - 07:43 PM
Just plug one of these bad boys in:
http://www.ebay.co.u...=item2c89e2cd16
All of your forced induction needs taken care of and more. It will probably reduce your BHP rather than raise it but at least it is lovely and shiney.
#10 Bandris11
Bandris11
  • 67 posts
Posted 28 September 2014 - 07:58 PM
Looks great! What if I put 2 of them straight away ?? :)
Anyway, Audi have some serious ideas about such electric turbo mods already... just give these guys a couple of years and we may see such things on the road!
#11 smiley
Posted 28 September 2014 - 08:21 PM
Specs say it could make about 0.1 bar.
That's about 12.5 bhp (and no cooling needed)
#12 slindborg
Posted 28 September 2014 - 08:26 PM
Looks great! What if I put 2 of them straight away ?? :) Anyway, Audi have some serious ideas about such electric turbo mods already... just give these guys a couple of years and we may see such things on the road!
Visteon added and electrically assisted turbo (vtes) to boost the output of small engines in 2002/2003ish..... IF its taken 10years to get nearly tested by the bigger companies then its not a huge step. Unless its like the f1 type of mgu boost add/control.
#13 siztenboots
  • 26,613 posts
Posted 29 September 2014 - 07:26 AM
or just the housing ?
#14 slindborg
Posted 29 September 2014 - 08:04 AM
If hes pulling it apart to change the FD, then simply use the box from the astra,,,
#15 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 29 September 2014 - 08:49 AM
I know it sounds ridiculous, but that electrical turbo charger has got to work on some level (presuming it is strong enough to overcome the regular airflow into the engine)
#16 fezzasus
Posted 29 September 2014 - 09:17 AM
It does, but only really integrated as a hybrid setup.
#17 slindborg
Posted 29 September 2014 - 10:12 AM
"That" one.... No chance.
A properly designed one, well of course, its working in F1, and has been proven a few tiems in the past 10 years (as I mentioned before)
#18 fezzasus
Posted 29 September 2014 - 10:35 AM
And electrical superchargers are being designed and tested for truck applications.
#19 Bargi
Bargi
  • 4,483 posts
Posted 29 September 2014 - 10:39 AM
Just supercharge it, well trodden path and lots options from here and the continent
#20 CocoPops
CocoPops
  • 17,181 posts
Posted 29 September 2014 - 11:47 AM
My thoughts too. Probably more proven than an engine swap now.
Also tagged with one or more of these keywords: engine;, motor;, swap;, turbo
