2004 VX220 Turbo Moonland grey. 64k Miles, Leather, FSH, HPI clear
In the last two years i've had the following done/Fitted
Engine mounts + poly inserts
Titan quick rack including new UJ's throughout the steering column
Track rod ends
Drop links
Team Dynamics TD1.2s
Cambelt @ 52k with all genuine parts including tensioners, water pump
Serviced @52k including plugs
Braided Hel brake lines
Performance Alloy radiator + silicon hoses,
Coolant tank with cap with a full coolant change
Serviced @ 55k
Brembo discs
Pagid blue brake pads all round
Quantum Zero dampers
Exige ABS unit
Upgraded hub carrier bolts's
Rear toe links
Serviced @ 59k
Courtenay precat replacement pipe + stage 1 map with air box mods 240bhp 295lb/ft
Courtenay fast road clutch @59k
Short rounded TAT rear diffuser
The dash plates have also been professionally painted black
While the previous jobs have been carried out all new stainless steel fittings have been used where possible.
The car is in great condition overall, the paintwork is all original and there is no sign of bubbling or cracking that i can see, there are some stone chips around the front of the car as to be expected after 10 years though.
The drivers seat also has a little hole in the common place that these seem to suffer.
For any further question please either PM me on here or give me a call/text on 07816341666 (if i don't answer please leave a message and i will call you back asap)
The car is located In Crowborough, East Sussex
£12,995ono
