Quantum Settings
35 replies to this topic
#1 vocky
Posted 18 October 2014 - 11:55 AM
what 'clicks' are people running their Quantum single adjustable suspension at  :poke:
I have searched :P  but could not find any mention of any base settings, for example: fronts 6 clicks from 0, rears 7 clicks from 0 etc
#2 pete-r
pete-r
  • 2,771 posts
Posted 18 October 2014 - 12:01 PM
My car is running very much a street setting. I have the fronts at -15 and the rears -12 on 300/425 springs. I know it sounds like it should be all woolie but the control on the shocks is so good and combined with the helper springs you get great bump comfort but with proper progressive cornering stiffness. Was going to stiffen the shocks up at track days but to be honest I've never felt the need, having tried it once and making the car a bit too 'understeery'.
#3 Matthew Bentley Racing Ltd
  • 774 posts
What spring rates are you running?
#4 vocky
Posted 18 October 2014 - 12:08 PM
450 front and 575 rears
#5 Matthew Bentley Racing Ltd
  • 774 posts
Posted 18 October 2014 - 12:12 PM
14 from full hard front and rear. Possibly 12 from full hard on the front.
#6 vocky
Posted 18 October 2014 - 12:13 PM
I will set them at 14r and 12f as a base setting and go from there  :)
Thank you Matt  Imnotworthy
#7 Matthew Bentley Racing Ltd
  • 774 posts
Posted 18 October 2014 - 12:25 PM
Wont be far off with that.
#8 Exmantaa
Posted 18 October 2014 - 06:58 PM
Interesting, as my single blacks now also tend to be set around 12-14 clicks too with 400-550 springs.
#9 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 18 October 2014 - 07:29 PM
I have mine at 15/17 from full hard front/rear for road. Crank em right up for track.
#10 Matthew Bentley Racing Ltd
  • 774 posts
Posted 18 October 2014 - 08:45 PM
God I'm good :P
#11 Scuffers
Scuffers
  • 1,306 posts
Posted 19 October 2014 - 12:37 PM
define "right up"?
if you going to stiffer than ~ -8, consider stuffer springs, your getting to the point of trying to use the dampers to hold the car up.
#12 pete-r
pete-r
  • 2,771 posts
Posted 19 October 2014 - 01:05 PM
Turn them up too stiff and you'll end up like mine was when messing around with the settings...
#13 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 19 October 2014 - 05:31 PM
define "right up"?   if you going to stiffer than ~ -8, consider stuffer springs, your getting to the point of trying to use the dampers to hold the car up.
Last outing I just kept winding clicks on until it felt right. Funnily enough it ended up at 10 and 12 from full hard :) Of you have them on full it's like driving on actual concrete.
#14 Matthew Bentley Racing Ltd
  • 774 posts
Posted 19 October 2014 - 06:51 PM
I have found a lot of owners keep winding their dampers harder and harder and the car handles better and better. All of those times I find that is because stopping the car moving and being able to roll masks geometry setup issues.
#15 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 19 October 2014 - 07:04 PM
I think you just end up hitting a sweet spot where the springs are working well with the dampers normally. The only times I've had to have geo redone have been when someone that doesn't know what they are doing has been buggering about with it before I've had it in. Surprisingly high profile snake oil salesmen as well! Nobody thats active on here I might add. IMO unless its going sideways or munching tyres just leave the fecker alone.
#16 Scuffers
Scuffers
  • 1,306 posts
Posted 20 October 2014 - 06:25 AM
Ah, OK, that's about right then...
(had visions of you running at -4)
exactly...   all sorts of kinematic issues can be masked by stopping the suspension moving!
#17 siztenboots
Posted 20 October 2014 - 07:58 AM
ding x1000
#18 vocky
Posted 27 October 2014 - 01:02 PM
Today I finally got around to driving my vx after fitting the Quantums  :blush:
As suspected the suspension height settled a little, so I had to return home to adjust the front ride height. I also dropped the shock settings from 12 to 13 (from full hard) at the front and 14 to 15 at the rear (from full hard).
The roads around Buckinghamshire are a little rough  :rolleyes:
First impressions;
A much firmer ride, which is what I sought, much less body roll and thus more confidence when taking corners at sensible speeds.
#19 siztenboots
Posted 27 October 2014 - 01:18 PM
do you have cornering force arb ?
#20 vocky
Posted 27 October 2014 - 03:13 PM
EliseParts 7/8" front anti-roll bar only, set at mid point of adjustment
