You really need the EP 1" ARB, no you really do!EliseParts 7/8" front anti-roll bar only, set at mid point of adjustment
Posted 27 October 2014 - 06:33 PM
Posted 27 October 2014 - 08:30 PM
I'm sure I do, probably
Posted 28 October 2014 - 08:18 AM
out of interest, what did you have before and what spring rates are you now on?
Posted 28 October 2014 - 08:36 AM
I was using Sachs shocks with their progressive springs, I wanted some Nitrons until you proved a point that Quantums are probably better
Now I have the latest Quantum single adjustable shocks with [color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;font-size:13.63636302948px;]450 front and 575 rears. [/color]
Height 130mm rear and 120mm front, with ATS dtc 17" wheels - 235 rears and 205 fronts. Not everyones first choice of wheel but I like them
Posted 28 October 2014 - 10:54 AM
450's is already something up front... You're not planning to go tracking with it now, do you??
(I now have 400-550 on my Q's, also with the 7/8th bar)
Posted 28 October 2014 - 11:47 AM
Well I did ask for 'fast road / a few track days a year' springs
Posted 28 October 2014 - 11:51 AM
as a general point, if your going to change your AR, not much point in buying one less than 1"
to put some numbers to this:
Std ARB is ~40"/lbs
7/8" ARB is basically 3 time stiffer, and adjusts from ~95 to 160"/lbs
1" ARB is 4.5 time stiffer adjusting from ~145 to 240"/lbs
Posted 28 October 2014 - 03:19 PM
So todays settings
I reduced just the fronts by one click each side, so front are now 14 clicks [color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;font-size:13.63636302948px;]from full hard and the rear are 15 clicks from full hard. This seems to work quite well with bumpy roads [/color][color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;font-size:13.63636302948px;] [/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;font-size:13.63636302948px;]Front springs 450 and [/color][color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;font-size:13.63636302948px;]Rear springs 575 - for future search references[/color]
Edited by vocky, 28 October 2014 - 03:20 PM.
Posted 31 October 2014 - 03:35 PM
Yesterday I set up the front and rear tracking with my Tecalemit tracking gauges, Front 0.4mm toe out overall and Rear 4mm toe in overall.
Took my vx out today and what a difference a few hours playing with the tracking can do
Edit: cos I'm stupid
Edited by vocky, 31 October 2014 - 03:47 PM.
Posted 31 October 2014 - 03:40 PM
+ve is normally toe in , and -ve toe out , which would make those figures look like they are inverse?
Posted 31 October 2014 - 03:47 PM
and there was me thinking that was a good way of saying toe out at the front and toe in at the rear
Posted 21 March 2016 - 05:35 PM
Anyone experience with 550 front and 700 rear for track only use?
What number of clicks would be a good starting point?
Posted 21 March 2016 - 09:02 PM
front 750lbs, rear 900lbs
Rebound rot Matt 16.1.16 Front left 11 Front right 11 Rear left 10 Rear right 10
Compression schwarz Matt 16.1.16 Front left 12 Front right 12 Rear left 12 Rear right 12
Posted 21 March 2016 - 09:30 PM
Eelco, I would start with something like:
Front: -12 from hard
Rear: -14 from hard
And work your way up from there. (Ask MaxR as he runs something fairly similar )
Edited by Exmantaa, 21 March 2016 - 09:31 PM.
Posted 21 March 2016 - 10:18 PM
Rear: -14 from hard
Harder at the front?
Would expect it the other way around.
Posted 21 March 2016 - 10:33 PM
Yep. On my car more rebound (so more hard) at the rear felt not so good on heavy breaking before the Tarzan and it probably lifted the rears a bit. But that was with 550/400.
