Compatible Parts
Posted 04 November 2014 - 09:33 AM
Posted 04 November 2014 - 09:34 AM
Posted 04 November 2014 - 10:22 AM
Also, just because it has a GM part number, it doesn't mean it's shared across the GM range.
For example, the above lotus part number you mentioned, [color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]A116J0003L also has a GM part number [/color]9197418. This is a lotus part though, not a GM part.There are other parts that are exclusive to our cars that don't have a lotus part number (e.g. the front V).
It's a bit of a minefield, but it becomes clear once you know the car better and understand what's shared between Lotus <-> VX and between VX <-> GM.
As a general rule:
- Only the engine components are shared across the GM range.
- The Lotus Europa is the closest match to our cars (however some parts on the VX are shared with the Elise and not the Europa...)
- Never buy you parts from Vauxhall. If it's a Lotus shared part; buy from Oakmere Lotus. If it's a VX part, try to find it second hand or ask on here if there's an alternative.
Hope that makes sense
Edited by Gedi, 04 November 2014 - 10:23 AM.
Posted 04 November 2014 - 10:24 AM
Use this site to locate shared lotus parts : http://www.deroure.com/
Use this site to locate VX only parts : http://www.speedster.../epc/index.html
Posted 04 November 2014 - 10:59 AM
