Obd2 Wiring Diagram
6 replies to this topic
#1 HOLTY
HOLTY
  • 9 posts
Posted 21 November 2014 - 05:31 PM
Hi All,
I have an OBD2 reader that works fine on my other cars, but doesn't power up in the VX220.
Upon closer inspection, it looks as if some wires may have worked their way loose from the back of the OBD port and therefore it is not working/has no power.
Would anyone have or know where I could obtain a diagram showing which wires should be connected to which ports in the rear of the OBD.
Cheers in advance
Holty
#2 Exmantaa
Posted 21 November 2014 - 05:52 PM
Pin 7 is is our ecu OBD connection (K-Line).
#3 HOLTY
HOLTY
  • 9 posts
Posted 21 November 2014 - 07:52 PM
Thanks Exmantaa - just need to work out which wires have come out and where they should go!
#4 techieboy
Posted 21 November 2014 - 07:55 PM
OBDII port is X13 on this diagram
http://www.speedster...nostic Link.pdf
#5 HOLTY
HOLTY
  • 9 posts
Posted 21 November 2014 - 09:29 PM
Thanks both - so looks like I have everything connected to the OBD port that should be - ports 3,4,5,7 & 12, with then 16 connected for power, but definitely not working with the reader. Two extra wires not connected (one red and one white) but these dont appear on that diagram.
Could the OBD port be broken? anything else I can try to isolate the problem?
Cheers in advance
#6 slindborg
Posted 23 November 2014 - 10:16 PM
Fuse 8 blown?
#7 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    motorsport especially BTCC
    rugby
    eating out
    keeping fit
Posted 24 November 2014 - 07:42 AM
Is it worth trying a different reader ? Just in case yours just won't talk to the Vx
