Hissing From The Supercharger
any ideas
12 replies to this topic
#1 MartinS
MartinS
  • 5,173 posts
  • Interests:Track days
    Pubs
    Sausages
Posted 27 November 2014 - 10:55 AM
When on tickover I can hear a hissing sound coming from the supercharger area which becomes a reedy hissing when driving. Car feels fine and cant see or feel any leaks anywhere.
Any ideas?
Martin S
#2 Stevie Dubyah
Stevie Dubyah
  • 1,534 posts
  • Interests:Invasive Operations
Posted 27 November 2014 - 11:02 AM
Any ideas?
Martin S
Is it a new build? Mine did that when a certain Norfolk based tuning shop kindly supplied manifold bolts that were 1mm longer than advertised, so they weren't torquing.
#3 techieboy
Posted 27 November 2014 - 11:17 AM
Try gently rocking the supercharger and see if the noise changes. VIX had a proper screeching noise when his had a leak betweeen the SC and the inlet manifold after one of the bolts had sheared and the noise changed as you pushed/pulled the supercharger body.
#4 siztenboots
Posted 27 November 2014 - 11:23 AM
squirt brake cleaner to find the leak , you will hear the change in engine note.
#5 fezzasus
Check all the bolts, when I stripped mine down to rebuild I noticed two bolts missing bolting the supercharger, must have rattled loose.
#6 furtive
furtive
  • 1,134 posts
Posted 27 November 2014 - 01:11 PM
Have you checked for snakes?
#7 siztenboots
Posted 27 November 2014 - 01:36 PM
going to be vacuum , check map sensor as well
#8 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 27 November 2014 - 03:35 PM
Supercharger is rock solid, and despite spraying stuff around no engine no change or sign of any leaks.
Remind me, wheres the map sensor? What other vacuum pipes are there as maybe one has a split or something and is sucking rather than blowing.
Martin S
#9 Steve.i.am
Steve.i.am
  • 990 posts
  • Interests:Bends
Posted 27 November 2014 - 04:10 PM
MAP sensor is on top of the inlet manifold on the right had side. Check AFR pipe also - its a thin pipe than takes off from the middle of the top of the inlet manifold and goes to the left hand end of the fuel rail.
Does it do it when you open the throttle and engine on boost? If not, it could be a leak pre-charger and post-throttle body? Theres a hole on the top of the charger which is usually blanked off with a bolt or redundant map sensor.
#10 CHILL Gone DUTCH
Posted 27 November 2014 - 04:17 PM
Brake vacuume pipe ? Could this be the bellow within the bypass
#11 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 27 November 2014 - 05:56 PM
Its hissing all the time, will check the above.
Martin
#12 Kieran McC
Kieran McC
  • 3,416 posts
Posted 27 November 2014 - 06:08 PM
Its hissing all the time, will check the above.   Martin
Try a spray of washing up liquid diluted spray it on the area , It will bubble up and show the leak.Or buy a aerosol leakdetector from a plummers merchant.
#13 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 01 December 2014 - 09:50 AM
Nothing found, Ho hum
Also tagged with one or more of these keywords: any ideas
