1.8 20Vt
262 replies to this topic
#161 Nev
Posted 06 February 2015 - 07:37 PM
sh*t the bed.
Wait till you get a ride in it, THATS when you'll sh*t yourself ! LOL
#162 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 06 February 2015 - 07:44 PM
Wow! Great project Great result! thumbsup
#163 Duncan VXR
Duncan VXR
  • 5,281 posts
Posted 07 February 2015 - 02:21 AM
Great result ;) top end power should be more than enough on track Get some graphs and pics up :) DG
#164 MAXR
MAXR
  • 2,719 posts
Posted 07 February 2015 - 10:01 AM
Don't forget to pack your Teflon coated pants...
...That may surprise a few cars down the straights!
#165 Hark
Hark
  • 3,443 posts
Posted 07 February 2015 - 12:43 PM
That's going to be suitably mental.
#166 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 07 February 2015 - 02:28 PM
My new solid gearbox bushes from Volksworkshop Motorsport
Why the switch to solids?
#167 techieboy
Posted 07 February 2015 - 03:07 PM
#168 techieboy
Posted 07 February 2015 - 03:09 PM
Excellent results Darron. :o
Fingers crossed on the reliability side of things, once it's back out on track proper. thumbsup
#169 Duncan VXR
Duncan VXR
  • 5,281 posts
Posted 07 February 2015 - 03:13 PM
Its a common upgrade on vag platform to reduce engine / gearbox movement under load but also if this conversion has gone with 2 top mounts and one bottom it would need either suitable upgraded ones and or solid to not have excessive movement. The vx220 gets a lot more traction than the donor fwd vag cars I used the vibratech uprated road spec tops and insert for lower one but after reviewing and discussing 4th mount was over kill DG
#170 Duncan VXR
Duncan VXR
  • 5,281 posts
Posted 07 February 2015 - 03:14 PM
My ex race car / track only is solid mounded engine and box ;)
#171 darronwall
darronwall
  • 2,706 posts
Posted 07 February 2015 - 04:33 PM
happy with that,need to fine tune a few bits and add a adj boost controller as the valve on the car doesn't like something about the setup and stopped us progressing,the positives are that everything else seems fine and it runs nice and cool and as it hit the 480hp on its first run its obviously fit for massive power.
back to thr dyno in a couple of weeks
#172 siztenboots
  • 26,613 posts
Posted 07 February 2015 - 04:45 PM
thats a good turbo choice, they really do flow a lot of air
#173 smiley
Posted 09 February 2015 - 02:34 PM
#174 darronwall
darronwall
  • 2,706 posts
Posted 09 February 2015 - 03:50 PM
going to go for a dat 80s ecu that should solve a small problem that stopped us on the dyno day and will give us traction control,launch control, in car switchable maps and also anti lag  and flat shift if we need them
 just need to decide wether to go cable throttle or spend more on the ecu side to cope with the fbw one,i am favouring the ecu route
#175 techieboy
Posted 09 February 2015 - 04:08 PM
What ECU had they been using up to now Darron? An Audi (Bosch) one?
#176 Nev
Posted 09 February 2015 - 05:23 PM
Nice and quiet :) Does that ECU offer gear dependant boost control, probably the single most important thing IMO.
Edited by Nev, 09 February 2015 - 05:25 PM.
#177 siztenboots
  • 26,613 posts
Posted 09 February 2015 - 05:26 PM
http://www.dtafast.co.uk/S_80_PRO.htm
#178 darronwall
darronwall
  • 2,706 posts
Posted 09 February 2015 - 06:41 PM
[quote name="techieboy" post="1765327" timestamp="1423498094"]
What ECU had they been using up to now Darron? An Audi (Bosch) one?[/quote
Yes ,
#179 darronwall
darronwall
  • 2,706 posts
Posted 09 February 2015 - 09:24 PM
yes it can,its no noisier than the let engine
#180 siztenboots
  • 26,613 posts
Posted 10 February 2015 - 09:37 AM
I think the issue you might have is the well known pressure cap in ME7.x at 2560mBar absolute pressure, this has in the past prevented us from installing a higher reading MAP sensor than the stock 2.5bar sensor.
The stock resolution is at 0.01bar or 10mBar, so the "5120" patch changes the axis scales on all pressures by -50% we end up with a resolution of 0.02bar or 20mBar. So you get full ECU control of pressure upto 5bar
tbh any vw+audi tuner should know this stuff
