What head gasket options are available for the 2.2 Z22SE and van anybody recommend a supplier? I am looking to up the na compression ratio.
Head Gasket Thickness & Compression Ratios
Started by
speedster
, Dec 04 2014 09:51 PM
head gasket compression ratio
3 replies to this topic
Posted 04 December 2014 - 09:51 PM
Posted 04 December 2014 - 10:38 PM
Z22yh gasket 0.37mm
Z22se gasket 0.49mm
Z20net gasket 0.98mm
1mm roughly equates to 1.00 CR on 86mm bore with 53cc of combustion chamber
Posted 04 December 2014 - 10:41 PM
Thanks oakmereZ22yh gasket 0.37mm Z22se gasket 0.49mm Z20net gasket 0.98mm 1mm roughly equates to 1.00 CR on 86mm bore with 53cc of combustion chamber
Posted 05 December 2014 - 10:46 AM
Also tagged with one or more of these keywords: head gasket, compression ratio
General Discussion →
VX220 Discussion →
Head Gasket Or Oil Cooler?Started by karmann , 08 Jun 2020 ![]() |
VX220 Discussion →
How Big A Job Is The Head Gasket / Changing The HeadStarted by Mc_Fudge3 , 06 Feb 2020 ![]() |
Tuning & Modifications →
Z22Se Cr & SkimStarted by speedster , 07 Feb 2015 ![]() |
Best Compression Ratio For Itb'sStarted by speedster , 02 Jul 2013 ![]() |
Some Qs About Fitting A Thicker Head Gasket Z20Le*Started by dedko , 30 Mar 2012 ![]() |
