Some more info about the engine and gearbox
Complete m32 6 speed conversion - £2000 (fitting is extra)
Gearbox has only done 5000 miles from new, supplied with 1st-5th gears from a corsa vxr, 6th gear from astra vxr
This gives excellent acceleration, similar ratios to a 4.55 F23
Rebuilt with brand new bearings
Helix clutch - less than 1k
Ttv custom flywheel - less than 1k
All mounts - less than 1k
Vockyd gear lever mechanism
Stage 3 SC engine - built from a saab b207 - £3000 (fitting is extra)
Built less than 1000 miles ago
GM Racing +0.5 oversized valves
Fully ported and polished cylinder head
CompCams Blower camshafts
Supertech double valve springs
Wiseco overbore forged low comp pistons 8.9:1, rebored block to suit.
Eagle steel rods
Balancer shaft delete
Balancer chain delete with Craig Davies electric water pump - but a standard pump can easily be fitted if required
Z22yh crank - this can be swapped for a z22se crank, PM Joe to discuss options
Saab high capacity sump
