Edited by christhegasman, 20 December 2014 - 01:31 PM.
Crash Box And Front Clam - Yup That Again!
#21
Posted 20 December 2014 - 01:30 PM
#22
Posted 20 December 2014 - 02:01 PM
Not sure I'd be as calm/mature as you.....I'd be back round his house with a length of 2x4I believe so... but lets not get messy - We're all big boys and best plan is just get it sorted... Caviat Emptor and all that...
That's a pisser mate
Did you buy from a forum member?
Dylan
Hope you get sorted quickly though. Few quid and I'm sure you'll have her back up and running in time for the better weather.
#23
Posted 20 December 2014 - 02:37 PM
Bad luck mate This confirms what I have said for years 1 don't be put off by cat cars 2 just cos it's not recorded dosent mean it's not been repaired Best of luck hope you find a decent crash box Try eljz parts on here Or Douglas valley breakers they always have a few The replica ones on eBay will look ok but not sure I would want to be in an accident with one of these
Yup the not being recorded thing can be a problem.
The Elise I had my accident in; £15.5K of repair work to put right, not recorded anywhere AFAIK. Already sold to a customer (after I drove it again)
G
#24
Posted 20 December 2014 - 02:50 PM
I've just nudged the batman about his crashbox but if you have no joy I may be able to source a new OEM one for you. If you need one let me know and I'll find out how much I can get one for.
#25
Posted 20 December 2014 - 05:19 PM
I hope you come through mate, easy to slate & your not doing that. All the best! These guys will help you on here, use them.
#26
Posted 20 December 2014 - 05:20 PM
#27
Posted 21 December 2014 - 08:39 AM
#28
Posted 21 December 2014 - 09:13 AM
#29
Posted 21 December 2014 - 01:55 PM
Im not here for blame or retribution or to devalue my car. In fairness the damage is simply someone who (like us all at one time) has over estimated theior driving and gone off into a kerb or verge. Its all low down and low energy - after all fibreglass has no real strength...
Im here to get the forums support to gget the vx back on the road for a modest cost so that I can enjoy it as I intended when I bought it a week ago,
In fairness the support and input I have recieved has been great, and its been a great opportunity for forums to do what they do best.
In the process I have learnt that so many cars hide damage, and in some respects I am glad I see it now, and glad that withe th vx that one can spend half an hour, get a clam off and inspect damage unlike a monocoque.
Be warned all new buyers... but then be realistic. If you are confident the chassis is straight then a cat car or unregistered damaged car might be a cheap route into great motoring...
D
#30
Posted 02 January 2015 - 06:59 PM
...so after much trawling of the web I am left to conclude the following
- If removing damaged crashbox and not bothered about it being intact then skilsaw it off to within an inch and then attack bit by bit using much time and hot knives
- If removing a crashbox from a damaged chassis best to cut a chunk of chassis off and take the aluminium off chunk by chunk...
- BUT, what if one wants to remove an intact or partially intact crashbox from an intact chassis? - What is the definitive method?
I am left to conclude it must involve some or all of the following (+ time):
- Hot thin knives
- Kevlar twine ('Gorilla cord' or 'Zipwire' - but cant find this in uk)
- A Fein multitool - strikes me one could damage the aluminium chassis with this unless a non-metallic blade were available
- Hooked stanley blades
Has anyone concluded the best way? - I dont mind if it take a huge amount of time, just need a method...
Thanks!
#31
Posted 02 January 2015 - 07:09 PM
I have removed a crashbox by chopping up the chassis, it's hard work
But basically yes to all of the items you mentioned and even more hard work
I would loosen the lower section and then attack the upper section with hot knives from each side, then use the cord / wire to cut the remaining central bonding splodge
#32
Posted 02 January 2015 - 07:14 PM
cheers vx220 - I suppose long knives from either side would be good - someone mentioned butcher spec ones... like a pallet knife...
any leads?
#33
Posted 02 January 2015 - 07:22 PM
See if you can acquire a portable hot wire cutter thats the only way I would even attempt to take a crashbox off. The OEM Elise one you can use is "only" about £1200 from memory. Is a used one worth the pain?
#34
Posted 02 January 2015 - 07:30 PM
hardtop guy - not sure i can see how hot wire cutter would work - will look into that
I appear to be able to get one for approx £1000 but its a last resort as this is all unanticipated cost and I see no reason why a well removed one couldnt be used.
Its a project and therefore my time is 'free' - unlike a garage or similar.
I'll go have a poke!
#35
Posted 02 January 2015 - 07:36 PM
OK member
#36
Posted 02 January 2015 - 08:20 PM
#37
Posted 03 January 2015 - 12:05 AM
#38
Posted 03 January 2015 - 09:08 AM
#39
Posted 03 January 2015 - 10:51 AM
#40
Posted 11 January 2015 - 10:58 AM
I'm trying to get hold of the adhesives etc for the crashbox. Some stuff avail at eliseshop - Betaseal @ £40.
If thats the cheapest then fair enough, but anyone have any / know of other places to get the stuff, or have a proven alternative method?
I know Tigerseal has been talked about, but not sure if the bond is proven on removed chassis to new crashbox?
I have currently removed the old box and taken the majority of the old adhesive off (to within 1/2mm or so)
Options:
A (As per service manual)
- Reactivate the chassis surface using betawipe 4000 (A082B6355V) (Silmid - £6 - 15ml)
- Clean crashbox with Betaclean 3900 (Isopropyl alcohol)
- Prime crashbox with Betaprime 5404 (A082B6337V) (Silmid £13)
- Bond with Betaseal 1701 (A082B6281F) OR: Betamate E2400 (A082B8415V) - Only one of these I can find is Betaseal @ £40 elise-shop
B
- Clean existing surface with isopropyl alcohol
- Prime crashbox and chassis with ? (FLD suggests a window fitting primer) - or could use Betaprime 5404 as its only £13.
- Clean crashbox with isopropyl alcohol (Lightly Abrade first?)
- Bond with tigerseal
What do you guys reckon?
thanks
Edited by dylan390, 11 January 2015 - 10:59 AM.
Also tagged with one or more of these keywords: crash box, crash structure, front clam, front bonnet, radiator surround, breaking, oem
General Discussion →
Tuning & Modifications →
Track Day Air Intake ModificationStarted by MAXR , 27 Sep 2018 ![]() |
The Market Place →
Car Parts For Sale →
Black Soft TopStarted by navx , 02 Sep 2018 ![]() |
The Market Place →
Cars For Sale →
Vx220 Na - Cat D - Cosmetic Front Clam - 53,000K - £5,900Started by London25 , 07 Dec 2016 ![]() |
The Market Place →
Oem Wheels On EbayStarted by ee601 , 21 Aug 2016 ![]() |
Anybody Know Who Did This ModStarted by speedster , 04 Apr 2015 ![]() |
