Edited by CHILL Gone DUTCH, 21 March 2015 - 09:27 PM.
Project: I Am The Resurrection
#221
Posted 21 March 2015 - 09:21 PM
#222
Posted 21 March 2015 - 09:25 PM
Oh did you not know he cut it all off? Well thats what he says, I think the local kids did it to him.
#223
Posted 25 March 2015 - 06:48 PM
Work has finally begun. Me and Steve got the rear clam (almost) off this afternoon and have also taken the supercharger off to aid access to the intake manifold for fitting the WMI.
Steve found a break in the anti lock braking wire that must have been triggering the safe mode and speedo failure so that's thankfully a cheap fix. Also discovered there's a coolant leak from the rad hosing somewhere and a hundred other little jobs that need doing.
WMI first though.
#224
Posted 25 March 2015 - 06:51 PM
#225
Posted 25 March 2015 - 07:30 PM
Clam would be off if someone remembered his keys.... dummy.
No point waiting for software, it can be all fitted anyway, you don't have to use it.
At the min we just want to get everything fitted and sort out all the other little niggles with the car.
Got to sort the leak from front end so will put the new V on at the same time for instance.
Thankfully the broken wire is at a previous repair above the plug with plenty of wire either side, so easy and no cost fix.
#226
Posted 25 March 2015 - 07:37 PM
Oh anyone know what is used to bond in the soft top retaining mounts on the top corners of windscreen? Looks like it locates and just uses sikaflex or alike to hold it in place, the load being taken by the location.
#227
Posted 25 March 2015 - 07:39 PM
I still think putting a big CC rad upfront will be the best investmentClam would be off if someone remembered his keys.... dummy. No point waiting for software, it can be all fitted anyway, you don't have to use it. At the min we just want to get everything fitted and sort out all the other little niggles with the car. Got to sort the leak from front end so will put the new V on at the same time for instance. Thankfully the broken wire is at a previous repair above the plug with plenty of wire either side, so easy and no cost fix.
#228
Posted 26 March 2015 - 05:10 PM
Bit more progress today. Intake manifold off and now with Steve for fitment of the nozzles. Two very awkward bolts took Steve about an hour to extract working from underneath the car with me holding the mani in position. If it wasn't for my knee I'd have been down there . Think the water tank will have to fit on the parcel shelf but we'll see.
#230
Posted 05 April 2015 - 11:27 PM
#231
Posted 05 April 2015 - 11:31 PM
#232
That was quick. Still need cleaning more.
#238
Posted 05 April 2015 - 11:36 PM
#239
Posted 05 April 2015 - 11:39 PM
They look better than that now Chris. Have a photo but lost my phone and can't upload it.
#240
Posted 05 April 2015 - 11:44 PM
Lots more pics but as above can't get them off my phone. This week should hopefully involve installing the WMI system. Or at least a start.
9 user(s) are reading this topic
0 members, 8 guests, 0 anonymous users
Bing (1)
