Project: I Am The Resurrection
820 replies to this topic
#241 piwo
piwo
  • 174 posts
Posted 06 April 2015 - 06:54 AM
 it looks like trabant now
Edited by piwo, 06 April 2015 - 06:57 AM.
#242 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 06 April 2015 - 01:04 PM
Thanks for making your 17th post in 4 years such an insightful one. It actually looks more like an Aviva bus. There's more green to the colour in the flesh
#243 piwo
piwo
  • 174 posts
Posted 06 April 2015 - 03:31 PM
#244 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 06 April 2015 - 06:59 PM
That pic of the cores was after a soak and wash. Just sent it to show how dirty they were, they are spotless now.
The bung is a potential WMI position Chris. May or may not be used, apparently gains are good from pre charger injection but I would like to test rather than take someones word for it.
#245 CHILL Gone DUTCH
Posted 06 April 2015 - 09:20 PM
look forward to your results
#246 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 08 April 2015 - 07:29 PM
We had a good 6.5hrs working on the car today.
Refitted the cleaned intake manifold. now with two WMI fitments and also popped the supercharger now with one WMI fitment back on (thanks again to Mr Crabash who worked wonders with the laminovas and the fitments).
After a little panic when the terminal came off the battery (and a plug we can't find another end for :unsure: ), it started again :)
This is what a cold SC engine with full decat Larini system sounds like. It shoots big flame when it's warm :D
#247 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 08 April 2015 - 07:38 PM
Also took most of the front clam bolts out, nice and easy as it's only just gone on.
Went at some corrosion on the sub frame with wire brush / rust remover / wire brush ready for painting.
Next week we will plum in the WMI tank and wire in the pump. We've been debating the best location for these. It's a tall, narrow tank. There is no room for it in the engine bay and I don't want it in the boot for space and weight distribution reasons so we think we have a nice spot for it on the parcel shelf. This will allow us simple access and a short route to the manifold and SC injection points.
Then it's off with the front clam, fix the leaking radiator, install brake cooling from the fog light apertures and generally tidy things up and rustproof as much as possible as we go.
Really hoping it will be ready for Angelsey.
#248 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 08 April 2015 - 07:46 PM
#249 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 08 April 2015 - 07:48 PM
WMI fitments with double and triple layer heat shrink for added protection.
#250 CHILL Gone DUTCH
Posted 08 April 2015 - 08:50 PM
Did you consider putting it on the 4 branches into the engine just before the map/ Tmap sensor area
#251 CHILL Gone DUTCH
Posted 08 April 2015 - 08:54 PM
What are you going to do about mapping ?? I thought you might need 2 maps one with WI and or without Which leads to my next question what are you going to do if WI runs out
#252 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 08 April 2015 - 09:30 PM
We will map it with and without. Defo doing two maps for both scenarios. Won't need to run the WMI in normal road driving.
#253 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 08 April 2015 - 09:57 PM
If water runs out failsafe conditions will activate.
No need to go as far as direct port inj for this level of boost and power, we are not trying to extract power, we want the cooling effect on the charge.
Edited by Crabash, 08 April 2015 - 10:09 PM.
#254 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 25 April 2015 - 04:19 PM
Bit more progress from last week.
Pipes connected to water injectors and heat shrink going over everything for added protection.
#255 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 25 April 2015 - 04:21 PM
Steve fitting the rivnuts to secure the water pump behind passenger seat.
#256 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 25 April 2015 - 04:22 PM
Cut down Jetex dB reducer. Will be held in place with circlips.
#257 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 25 April 2015 - 04:23 PM
Rust treated, etched and painted rear sub frame looking much better now
#258 Acidpopstar
Acidpopstar
  • 3,556 posts
#259 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 25 April 2015 - 04:25 PM
Steve doing lots of thinking and dealing with many wires. I am trusted with hammering, drilling, cutting and filing duties only.
#260 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 25 April 2015 - 04:26 PM
Parcel shelf modified so that pump can fit snugly.
Back to it on Monday.
    Bing (1)
