Project: I Am The Resurrection
820 replies to this topic
#381 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 20 June 2015 - 10:47 PM
Great result - you must be happy with that!
Possibly good enough to dump the laminova's and CC system and run WI on it's own....
#382 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 20 June 2015 - 10:53 PM
I had thought that you could do that if you mapped the WI for it and you would remove quite a restriction and some weight.
#383 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 20 June 2015 - 10:59 PM
Human error would result in the tank not being topped up IMO.
#384 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 20 June 2015 - 11:00 PM
It really shows how well the WI keeps the temps down its a great result Can't believe how quickly temps go up when I assume the WI is not running or low revs/load Good work with
It is possible we have it mapped to activate at too high a point and therefore part throttle through the corner is not kicking it in. But yes it does climb fast at low or off throtlle conditions.
#385 CHILL Gone DUTCH
Posted 20 June 2015 - 11:02 PM
Are you running the laminovas with the small rad in ear ??
#386 Crabash
Crabash
    Scared
  • 1,686 posts
It tells you if it's empty, which can also be used to put car in limp to protect it.
Having said that for most people I would leave a cooler of some kind in there.
Edited by Crabash, 20 June 2015 - 11:04 PM.
#387 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 20 June 2015 - 11:03 PM
Enough of a result to prove there's no point in the charge cool rad though. And I have no issues with hot coolant temps as have no CC rad to block the main rad. Never got above 90 all day long.
Very happy, very tired, very mashed now the beer is working with the meds :blink:
#388 Exmantaa
Posted 20 June 2015 - 11:43 PM
Second session, WI on
That is bloody good! And much lower measured temps than my mates Harrop + WI, but he injects before the throttlebody. (No vacuum there, because there's no danger that you suck in water though a leaky nozzle..)
We should try your nozzle position.  :happy:  Is this pure water or water + methanol mix?
Edited by Exmantaa, 20 June 2015 - 11:47 PM.
#389 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 20 June 2015 - 11:57 PM
Just water :)
#390 CHILL Gone DUTCH
Posted 21 June 2015 - 07:39 AM
One thing I did notice about the two graphs is how bad you small rad is on its own Are you going to be doing experimenting with when it activated etc Do you think the people using the rad upfront (cc) will see the same results (temps) as you Or will they be lower ( at stage 2 SC ) as your WI must be battling harder because of the small CC I'm not trying to put a dampener on this for you as it's clearly working extremely well on your car and setup 😜
#391 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 21 June 2015 - 10:53 AM
Exmantaa, you just add a 15 psi check valve behind the jets to stop leaks under vac. Chill, dont think the min temps will be much if any different. Overall average will be lower though due to the off/low load cooling being better. But I'm confident we can improve that too when I actually set it up. Currently its on a generic safe set up hence comes in quite late in the duty cycle.
#392 techieboy
Posted 21 June 2015 - 03:45 PM
Glad, but not surprised, it worked so well. thumbsup Will be interesting to see what Peter comes up with with his built-in water injection control in OBDTuner when he releases it. Last time I spoke to him, he too is basing his control strategy on IDC, plus, I think, a couple other ECU parameters. Also adding some settings for specifying the water/meth mix and using the unused PWM output on the EGR connector (still leaves the wideband input intact). Will still need all the pump, tank and injector gubbins but assume that will mean an external controller isn't needed which should save a few quid (though I guess you might need to send the ECU back to him for updated firmware).
#393 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 21 June 2015 - 03:58 PM
Yeah I'm interested to see what he comes up with. Not sure if Aquamist sell the pump separately from the controller.
#394 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 21 June 2015 - 06:05 PM
Yeah they do but also your system has a data connection for ecus that can handle that. Basicly lets the ecu control through the aquamist box so there are no worries about power requirements for pump, solenoid etc.
#395 CHILL Gone DUTCH
Posted 22 June 2015 - 03:37 PM
Did you remap the car with WI on or just run it on the normal map Have you noticed if the AFR are ok or are they not affected by WI ?
#396 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 22 June 2015 - 04:14 PM
Same map as we did over at yours Chris. We need to spend some time tweaking the HS2 controller and mapping over the next few weeks to get the most from the system.
I'm sure Crabash will be along soon re AFRs. Looking at the two logs the Target AFR (is that right?) values are identical.
I did have a reply from Peter after I sent him the logs. He says he has had similar results and can't understand why people are so negative about WMI. Also that it cools your exhaust gases thus making packing material last longer etc. He goes on to say we may have trouble adding alcohol because it will get difficult to tune as it's difficult to control AFRs with the system. He has some new features implemented on the new system but not WMI yet. He is dedicating all his spare time to it.
#397 CHILL Gone DUTCH
Posted 22 June 2015 - 04:25 PM
You need a wideband to measure the AFRs Not sure if you have one The target AFR are what you want your AFRs to be not what they are
#398 CHILL Gone DUTCH
Posted 22 June 2015 - 04:26 PM
You could look at your fuel trims but this is not very accurate
#399 CHILL Gone DUTCH
Posted 22 June 2015 - 04:30 PM
That's a very good point about the exhaust wadding last longer never thought of that Have you got links for your kit you used ??
#400 techieboy
Posted 22 June 2015 - 04:37 PM
Unless somebody has some temp readings that prove otherwise, I don't think heat is an issue for the wadding. Certainly not if you're using the high temp stuff. 95% of mine is pristine and the binding threads haven't even melted to let it fully expand. That's for the main silencer and the the small cat replacement silencer.
    Bing (1)
