Project: I Am The Resurrection
820 replies to this topic
#541 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 03 March 2016 - 01:09 PM
I'm sure it is!
#542 stu8v
stu8v
  • 745 posts
Posted 03 March 2016 - 01:15 PM
Loud pipes save lives.
#543 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 03 March 2016 - 02:22 PM
:D
#544 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 09 March 2016 - 07:11 PM
Posted Image Liam made the WI bottle fit behind the harness bar :)
Edited by Acidpopstar, 09 March 2016 - 07:14 PM.
#545 CHILL Gone DUTCH
Posted 09 March 2016 - 07:22 PM
Is it running now
#546 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 09 March 2016 - 11:43 PM
Is it running now
Yep, he wouldn't be putting it back together otherwise. He's replaced / cleaned loads of contacts and relays until it started with the new fuel pump.. Might even be ready to collect this weekend. Anyone fancy a trip to MMG from my neck of the woods?
#547 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 10 March 2016 - 08:15 AM
Great news glad it's up and running.
Hope your back has improved s you can enjoy the car.
#548 ciderbooze
ciderbooze
  • 1,222 posts
Posted 10 March 2016 - 10:55 AM
Is it running now
Working sorry. Good news though!
#549 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 11 March 2016 - 09:03 PM
Issues with getting seats to fit mean the car isn't year ready to collect. Liam sent me these pics which shows how tight it is in there for space.
#550 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 11 March 2016 - 09:17 PM
Issues with getting seats to fit mean the car isn't yet ready to collect. Liam sent me these pics which shows how tight it is in there for space.
Apparently Tillett B5s aren't as much of an issue but as the B6s are a race seat it's tricky especially as I ordered a passenger seat as well. Also need a new fixing that Tillett have developed so I can retain the seatbelts, and Luke sent the lap belts with the wrong fixing so I I've asked for a replacement. Might not even be ready next week now.
Gonna look great when they're finally in though.
#551 Kieran McC
Kieran McC
  • 3,416 posts
Posted 11 March 2016 - 09:40 PM
I think you may struggle to refit the consol with both of the B6's in place ,
#552 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 11 March 2016 - 11:44 PM
Indeed fella.
#553 TazN
TazN
  • 2,931 posts
Posted 14 March 2016 - 08:48 PM
Not a big issue though, not had mine in for a year or so now.
#554 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 01 April 2016 - 09:11 AM
Liam has finally finished working on the car. It's gone massively over budget due to all the rotten electrics so I'm truly skint now. Jobs done by MMG: Replace fuel pump with Spitfire uprated pump. Spent a week diagnosing then fixing myriad electrical problems so the car started and ran. New plugs. Fit 2 x Tillett B6 custom carbon seats. Fit harness bar and harnesses. Fit tubby back box to Larini decat system (depending on how I get on with this I may have a Larini back box for sale. Fit EP lightweight disks, RS14 pads. Refurbished all four brake calipers. I've left the 1" ARB off. I'm not convinced it will make enough difference to justify the cost of fitting it. Want to try a similar set up car (Captain Vimes?) That has one fitted then I'll make my mind up. May also sell this. Going down to collect it next week and just want to enjoy some trouble free driving for the rest of the year.
#555 ciderbooze
ciderbooze
  • 1,222 posts
Posted 01 April 2016 - 09:23 AM
Just in time for the summer sunshine.! Nearly there.
#556 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 01 April 2016 - 11:12 AM
Good to hear it's back in one piece! Is your back actually allowing you to drive it? You're welcome to have a drive of mine to get a feel for the ARB but suspect the overall feel will be more affected by geo..? From memory you have relatively soft front springs? If you're sticking with the standard ARB you might want to consider increasing front spring rate instead? Cost of springs are around £70 and fitting is pretty simple.
#557 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 01 April 2016 - 12:37 PM
I guess I'll find out next week when I pick it up and drive the 3hrs home :mellow: I've 'practised' by sitting in the seats on the floor and going through the motions. Think I'll be ok but getting in and out will now be done soley via the roof! Thanks for the offer of a drive - yes I have soft springs. What are your geo settings out of interest? Are springs £70 for a set?
#558 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 01 April 2016 - 04:23 PM
£70 for 2 including delivery (faulkner springs). Got mine from demon twits. I've lost track of geo on mine. But basically: - Toe = straight ish (some toe in at the rear) - Camber = no shims but still need more negative camber at the front. - Height = lowest it'll go without loose springs. Which is about 130/115 but I haven't checked it since changing springs as my drive isn't flat enough. Spring rates 525r/350f with 1" ARB on middle setting. The key for me was getting the front/rear roll stiffness working together. The 350f only works with the 525 rears because I have the 1" ARB. I'd like to test a much stiffer setup at some point though just to see how it feels but going stiffer than I am requires the use of tender springs and damper revalved which means £££ Good luck driving it! I hope it's not too uncomfortable!
#559 Jason
Jason
  • 1,327 posts
  • Interests:Trackdays, Walking, Photography
Posted 03 April 2016 - 08:57 AM
The water tank look a lot shallower than I remember. That does look like a PITA to fill. A container similar in shape to the fuel tank in the same location would lend to a more discreet install. I expect finding a suitable container is difficult though. Thinking out loud here as really like this install/solution.
Edited by Jason, 03 April 2016 - 09:19 AM.
#560 smiley
Posted 03 April 2016 - 09:26 AM
The washer fluid container is rediculously big, and can be replaced with a small one on the tyre pressure can location.
Then you can fit a 5 liter container over the battery. (have not found a suitable one yet though)
Edited by smiley, 03 April 2016 - 09:27 AM.
