Project: I Am The Resurrection
820 replies to this topic
#601 1cobrav8
1cobrav8
    Joe is faster than me
  • 516 posts
Posted 21 June 2016 - 08:01 AM
Also took most of the front clam bolts out, nice and easy as it's only just gone on.
Went at some corrosion on the sub frame with wire brush / rust remover / wire brush ready for painting.
Next week we will plum in the WMI tank and wire in the pump. We've been debating the best location for these. It's a tall, narrow tank. There is no room for it in the engine bay and I don't want it in the boot for space and weight distribution reasons so we think we have a nice spot for it on the parcel shelf. This will allow us simple access and a short route to the manifold and SC injection points.
Then it's off with the front clam, fix the leaking radiator, install brake cooling from the fog light apertures and generally tidy things up and rustproof as much as possible as we go.
Really hoping it will be ready for Angelsey.
Did you try the tank in the right hand sill area at all? That's where i'm thinking of fitting mine but if the aquamist tank wont fit there i best have a rethink....
#602 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 21 June 2016 - 09:11 AM
[/quote] Did you try the tank in the right hand sill area at all? That's where i'm thinking of fitting mine but if the aquamist tank wont fit there i best have a rethink.... [/quote] I didn't. It's still on the parcel shelf and fits perfectly if very snugly even with the harness bar installed. Do you mean down the side of the seat? It might fit there if you have narrower after market seats. I have B6s and there is certainly more room down there than with standard. Don't forget though that it's not just the tank - the pump has to be securely mounted nearby as well. Sent from my iPhone using Tapatalk
#603 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 21 June 2016 - 10:29 AM
Think I know where you mean. Although forget right hand try left though, fuel filler provision in bulkhead encroaches in the right hand side, never tried on Neil's as it would make filling difficult, but I have looked at this area for my own. It might fit but suspect the gap gets too narrow at top, unless you go for different tank. This is what I may do, I have other plans for filling.
Edited by Crabash, 21 June 2016 - 10:32 AM.
#604 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 21 June 2016 - 11:19 AM
Just looked again and it won't go by the seats. Sent from my iPhone using Tapatalk
#605 techieboy
Posted 21 June 2016 - 11:29 AM
I've looked at exactly that. Even looked at rotomolding/rotocasting to make a custom shaped container that would go all the way down into the end of the sill. I've got the same skinny tank that Neil has and think it might be possible to get that in the left hand side of the engine bay but will probably need an ecu relocation (again) and a lot will depend on the air filter solution. I also got a remote filler for the tank to situate somewhere easier to fill through. As ever, lack of arsedness is the killer as I really don't want to remove the clam again and until I finally settle on an airbox setup to kill the noise, I'm not sure of what space I'll have. The only thing I'm sure of is that neither the tank nor the pump will be going in the interior. I value the parcel shelf too much and if necessary will get ProAlloy to knock something up to fit across the width of the boot bulkhead without taking up too much space.
#606 CHILL Gone DUTCH
Posted 21 June 2016 - 11:54 AM
I will be using the washer bottle to start with until I get the feel for how much water I will need and time of filling back up Might look at getting a larger tank in same place which will also do Windows and wi Other thing to think about the pump needs to be lower than the tank So was thinking of putting the pump in cabin maybe behind a seat or foot well area
#607 Jocke_D
Jocke_D
  • 407 posts
Posted 21 June 2016 - 01:34 PM
To me the boot seems like the obvious place to put the tank. What am I missing?
How does heat affect the water tank? Less hot water into the manifold would be better than hot water I guess (thinking about the idea above of putting it next ot the engine)?
#608 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 21 June 2016 - 03:29 PM
You could use 2 smaller tanks feeding a T piece to the pump, this might give more freedom for location. And remember any pipe work from the tank to the pump will act as anti surge if you have unbaffled tanks.
The pump can be higher than the tank if you fit a non return valve at the low point.
Don't forget the cap should be vented, so if you plan on using Meth that vent will need routing out of cabin.
Edited by Crabash, 21 June 2016 - 03:32 PM.
#609 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 21 June 2016 - 04:45 PM
The idea that I have eventually is to get a custom baffled alloy tank the same dimension to one of these
They are impact foam that slots into the lotus sills at the rear of the sill. I reckon one will easily hold 5 litres plus. I know it's for the lotus sill but I'm sure you could get something similar made to work.
You can see one of them fitted just below my catch tank
Edited by haggi961, 21 June 2016 - 04:46 PM.
#610 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 21 June 2016 - 05:16 PM
Can't use ally with meth FYI
#611 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 21 June 2016 - 06:05 PM
The tank will be getting hard Anodised to stop this. Been doing some reading on this and 50/50 mix isn't a harsh as full on meth and make sure the tank is drained if left for long periods of time.
#612 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 30 July 2016 - 02:45 PM
So, I killed my engine. Nothing to do with trying to extract more power. Just neglected to top the oil up due to not having time to get the boot open and check for a few weeks. Fessing up is hard to do :blush:
It needed 3 litres so I'm guessing it was on it's way out anyway. But :ffs:
Hoping ChrisUK at Jon Seal's Sportcars can work a miracle and fit a replacement before Zandvoort...
#613 The Batman
Posted 30 July 2016 - 04:46 PM
If they can't do it bud I'm sure we can get you sorted :)
#614 vocky
Posted 30 July 2016 - 05:05 PM
Joe has a very cheap engine available :D
#615 Bargi
Bargi
  • 4,483 posts
Posted 30 July 2016 - 07:18 PM
Did you have a standard sump or Saab?
#616 vocky
Posted 30 July 2016 - 07:29 PM
Acid had a std z22se engine
#617 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 30 July 2016 - 09:36 PM
Yeah totally standard second hand engine which had 26k on it when I bought it from Liz about 3 years ago. I've put about 40k on it in that time including SCing it and track days. I guess i have to treat the engine as a consumable due to the abuse it gets. But keeping the fecker topped up with oils helps! Sent from my iPhone using Tapatalk
#618 Bargi
Bargi
  • 4,483 posts
Posted 30 July 2016 - 09:39 PM
Best you get a nice big Saab sump next time :D Gutted mate. It's nightmare these engines and measuring oil.
#619 CocoPops
CocoPops
  • 17,181 posts
Posted 30 July 2016 - 10:02 PM
Get a Saab engine... They just drop right in, no messing :lol: :rolleyes:
#620 ciderbooze
ciderbooze
  • 1,222 posts
Posted 31 July 2016 - 08:21 AM
Ffs that's a ball ache you could do without.
