Project: I Am The Resurrection
#641
Posted 16 August 2016 - 07:24 PM
#642
Posted 17 August 2016 - 12:16 PM
I can't wait for Zandvoort again. Will have a lot more confidence next time. Drove to work in the VX today. Teeth nearly rattled out my skull - Christ those ZZRs are hard! Sent from my iPhone using TapatalkZandvoort is quite a daunting track The zzr I think are awesome and I don't think I've pushed them very hard yet Once you find some rhythm at zandy the times do just drop
#643
Posted 30 November 2016 - 02:55 PM
#644
Posted 30 November 2016 - 03:54 PM
#645
Posted 30 November 2016 - 03:56 PM
#646
Posted 30 November 2016 - 03:58 PM
Roof ballooning is likely the front cable is either not tight enough or broken. Tried driving mine with a broken cable while waiting for a replacement and the same happened. will also happen if the soft top isn't seated in the roof seal properly.
Edited by fezzasus, 30 November 2016 - 03:58 PM.
#647
Posted 30 November 2016 - 09:05 PM
Cheers Tom, I really hope it's just the cable. Not been to look at it properly yet. Sent from my iPhone using TapatalkRoof ballooning is likely the front cable is either not tight enough or broken. Tried driving mine with a broken cable while waiting for a replacement and the same happened. will also happen if the soft top isn't seated in the roof seal properly.
#648
Posted 08 December 2016 - 09:37 PM
#649
Posted 09 December 2016 - 09:04 AM
Have you tested if there's demand for a rebuilt engine?
My concern would be that you'll drop a lot of money on parts to build a upgraded engine only to find that it only worth the sum of it's parts (or less). Keep in mind that once you start looking at custom engine territory there are a lot of variables that are dependant on the application; compression ratio, cam profile and lift being the main two. You could end up spending lots of money to fit pistons and cams that people don't want for their application and won't pay for.
#650
Posted 09 December 2016 - 10:42 AM
It is a slight concern. Although the engine will be near standard with the addition of Eagle steel rods and a balancer delete so should open the market up to most people who want a replacement engine. Sent from my iPhone using TapatalkHave you tested if there's demand for a rebuilt engine? My concern would be that you'll drop a lot of money on parts to build a upgraded engine only to find that it only worth the sum of it's parts (or less). Keep in mind that once you start looking at custom engine territory there are a lot of variables that are dependant on the application; compression ratio, cam profile and lift being the main two. You could end up spending lots of money to fit pistons and cams that people don't want for their application and won't pay for.
#651
Posted 09 December 2016 - 12:59 PM
Storage costs for the knackered one are at £648.32 as we stand
#652
Posted 27 December 2016 - 09:19 PM
#653
Posted 27 December 2016 - 09:46 PM
#654
Posted 27 December 2016 - 09:52 PM
#655
Posted 28 December 2016 - 12:21 AM
Cheers Stuart, dunno what I've done to deserve her but I count my lucky stars every day. And I'm looking forward to the wedding as wellWhat are you doing about your exhaust system and pulley size on the new engine? Or will you be sticking at a safe stage 2 build? P.S congrats on spending the most amount of money on one day. (I mean the wedding, not the car).
#656
Posted 28 December 2016 - 12:23 AM
Cheers Malcolm. Are you coming to the national? Still hoping you may be able to help out with that engine transport but let me know if it's not possible and I'll sort freight. Think I've taken the p*ss for long enough leaving it at Jonny'sCongratulations mate, excellent news..dodged a bullet on that soft top. Good luck on the trips! Oh & well done the wedding plans for you and your lass
#657
Posted 02 January 2017 - 02:38 PM
Went across to hook up my new CTEK MXS 5.0 charger today. Thought I'd try starting it up while I was there and was astonished that it fired up first time and went into a nice idle. Not bad for not being touched since early September!
While I was there I noticed a damp patch under the rear O/S brake calliper and remembered that I drove round Europe with a leaking calliper nipple. I'm sure I have a spare somewhere.
So jobs are - engine replacement, calliper nipple, fix heater, and if I can be arsed replace the fan and that also gave up when we got to France.
And probably loads of other things I've forgotten / haven't been aware of.
#658
Posted 25 February 2017 - 01:04 PM
#659
Posted 26 February 2017 - 05:45 PM
It was all good on the long drive home and I'm really looking forward to mapping it. May experiment with a smaller pulley and water meth now I know I'm not gonna break the engine.
Lee was brilliant. Very hospitable and clearly know these cars inside out. He spotted a couple of things that were missing / broken / unattached and sorted them as he went. Thanks again mate and good luck with your monster engine build, that thing is gonna be mental.
Edited by Acidpopstar, 26 February 2017 - 05:47 PM.
#660
Posted 26 February 2017 - 07:54 PM
Glad your Happy mate and you got home ok , happy mapping and mething ;-)
Bing (1)
