Project: I Am The Resurrection
#681
Posted 26 May 2017 - 10:51 AM
#682
Posted 26 May 2017 - 12:36 PM
The pump is a Spitfire fuel pump that is less than 2 years old so I would really hope it's not thatHow old is the pump Neil Is it worth trying to swap out the pump for a other or even having your pump tested ? The other thing you could try is when the pump dosent prime test to see if you have the voltage at the pump plug This way you will no if it's pump or external from pump
Edited by Acidpopstar, 26 May 2017 - 12:36 PM.
#683
Posted 26 May 2017 - 01:49 PM
I'd be more inclined to say it's the relay.
#684
Posted 26 May 2017 - 01:59 PM
i do agree it could be the relay
but thought this would be a easier test to confirm if the voltage is getting to the pump
if Neil was going to test it himself
but if he is going to get someone who knows there way around relays and electrics then it might be worth going straight to the relay
i actually still think its a poor earth or connection or it could even be the battery is breaking down under load (ignition)
Edited by CHILL Gone DUTCH, 26 May 2017 - 02:01 PM.
#685
Posted 26 May 2017 - 02:12 PM
How much load does the battery experience once the alternator is working?
If this is just preventing starting, then i'd agree that it might be dodgy connections between the battery and ground, however i'd also look at the exciter going to the starter motor. This is a very small wire and could easily corrode or become damaged.
#686
Posted 26 May 2017 - 02:25 PM
you will probably find lambda and fuel pump CC pump so probably adds up
ive also known a starter motor to cause all kinds of issues acid might also have his water injection pump
#687
Posted 26 May 2017 - 02:56 PM
#688
Posted 26 May 2017 - 03:37 PM
Edited by CHILL Gone DUTCH, 26 May 2017 - 03:37 PM.
#689
Posted 26 May 2017 - 03:41 PM
there is also a negative cable between the gearbox and chassis, which can also cause poor starting
#690
Posted 02 June 2017 - 04:52 PM
Second coat of primer
#691
Posted 02 June 2017 - 04:53 PM
#692
Posted 05 June 2017 - 02:08 PM
#693
Posted 05 June 2017 - 02:30 PM
#694
Posted 05 June 2017 - 04:12 PM
Looks amazing
#695
Posted 05 June 2017 - 08:11 PM
Very nice (again), lucky to have a good painter close by
#696
Posted 07 July 2017 - 02:12 PM
Gutted to not be travelling to Pembrey for the National today but I had to see my slot due to ongoing issues. Hope to see you all next year!
Steve (Crabash) helped me with the problem rear calliper today. Thankfully it appeared to be sticking sliders caused by the rubber seals perishing. Steve dismantled it, re-greased the sliders and put back together and it seems to have temporarily cured to problem. A caliper refurb kit is on order.
Steve confirmed what I feared with regards to the play in the front right wheel - I need a new rack. I am skint and have Spa at the end of the month so not sure what I'm going to do as I can't face missing that as well as the National.
The electrical gremlins on start up have stopped since I removed the bluetooth dongle from the port under the dash. Fingers crossed that's all it was.
I realise these updates are not particularly thrilling and that anyone with a modicum of mechanical know how will be shouting at the screen by now. I know an awful lot more than I did when I bought the car but I'm reliant on others expertise more often than not. This is more of a log of what issues I've experienced so I can trouble shoot in the future.
#697
Posted 08 July 2017 - 07:51 AM
If it's cup wear, rather than tooth wear on the rack (which sounds like it is given you're seeing play on one side). You can purchase replacement bronze cups for the rack providing you have a titan rack.
https://www.seriousl...hor-bronze-cups
From memory the work involves drilling out a locking pin, swapping them and fitting a new locking pin.
#699
Posted 08 July 2017 - 09:50 AM
Cheers Tom. Mine is a Y reg 2001 so would that be a Titan rack? I'll do a search Sent from my iPhone using TapatalkIf it's cup wear, rather than tooth wear on the rack (which sounds like it is given you're seeing play on one side). You can purchase replacement bronze cups for the rack providing you have a titan rack. https://www.seriousl...hor-bronze-cups From memory the work involves drilling out a locking pin, swapping them and fitting a new locking pin.
#700
Posted 08 July 2017 - 09:57 AM
He commented on how good quality the Jon Seal front clams are, the best fibreglass products he's seen apparently. Sent from my iPhone using Tapatalk
He must have got one of the special ones the apprentice didnt make
