Project: I Am The Resurrection
820 replies to this topic
#701 fezzasus
Posted 08 July 2017 - 10:26 AM
If it's cup wear, rather than tooth wear on the rack (which sounds like it is given you're seeing play on one side). You can purchase replacement bronze cups for the rack providing you have a titan rack.    https://www.seriousl...hor-bronze-cups   From memory the work involves drilling out a locking pin, swapping them and fitting a new locking pin.
Cheers Tom. Mine is a Y reg 2001 so would that be a Titan rack? I'll do a search Sent from my iPhone using Tapatalk
Yes, it'll be a titan rack.
#702 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 09 January 2018 - 08:29 PM
#703 smiley
Posted 09 January 2018 - 08:51 PM
Not having much luck with it lately huh.
#704 SteveA
SteveA
  • 9,155 posts
Posted 09 January 2018 - 09:01 PM
Not again :( you thought about buying your own flatbed yet 😄
#705 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 10 January 2018 - 12:10 AM
Not again :( you thought about buying your own flatbed yet �
I’ve thought about many things, most involve a can of petrol and a box of matches :D Sent from my iPhone using Tapatalk
#706 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 10 January 2018 - 12:11 AM
Nope. Although this is related to the drive shaft popping out at Spa. Needs further diagnosis Sent from my iPhone using Tapatalk
#707 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 10 January 2018 - 06:03 AM
#708 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 10 January 2018 - 08:10 PM
At my house now. Pending gearbox replacement ! Sent from my SM-G903F using Tapatalk
#709 CHILL Gone DUTCH
Posted 10 January 2018 - 09:20 PM
Sequential gearbox ?
#710 smiley
Posted 10 January 2018 - 09:42 PM
Was the ring that is suppose to keep the shaft in worn?
#711 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 10 January 2018 - 11:05 PM
:D in my dreams along with a Hayabusa V8 Sent from my iPhone using Tapatalk
#712 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 10 January 2018 - 11:06 PM
Not particularly. Replaced but still no drive when in gear. Sent from my iPhone using Tapatalk
#713 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 11 January 2018 - 08:59 AM
Diff has gone, and the symptoms in part were the shaft was kicked out, hence in putting it back in there is now no drive.
#714 CHILL Gone DUTCH
Posted 11 January 2018 - 11:13 AM
Don't forget a new clutch slave cylinder , and check shaft gearbox seals Seems a waste to change it all to do it all again Clutch ?
#715 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 11 January 2018 - 12:41 PM
Agree and will be giving the car a full once over including fitting a new matrix for the heater.
#716 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 11 January 2018 - 10:06 PM
Ah might have to eat humble pie here, I had assumed the clutch was OK as it felt good under foot.
Does explain why with one side jacked up and in gear the wheel rotated freely !Posted Image
#717 CHILL Gone DUTCH
Posted 12 January 2018 - 06:29 AM
This is what happens when your go above stage 2 Everything else needs updating Welcome to the forged engine club where you just spunk even more money at the car
#718 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 12 January 2018 - 08:45 AM
its a Helix.
ie uprated Courtney Sport.
#719 Exmantaa
Posted 12 January 2018 - 09:11 AM
How much HP?  Around 300 you can fit a cheap C20LET clutch. :happy:
#720 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 12 January 2018 - 10:37 AM
It’s only running 250 ish though. Obviously Lee was running a lot more though Sent from my iPhone using Tapatalk
