Project: I Am The Resurrection
820 replies to this topic
#721 CHILL Gone DUTCH
Posted 12 January 2018 - 12:39 PM
Did you car not take a battering when you collided with the corsa when you smashed a wheel
#722 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 12 January 2018 - 02:20 PM
When the Corsa collided with me his wheel clipped mine and fcuked the TD. This was a front wheel though so won’t have affected anything. Sent from my iPhone using Tapatalk
#723 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 19 January 2018 - 02:15 PM
John just can’t stop making stuff. Bespoke custom heater he is currently working on. Posted Image
#724 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 19 January 2018 - 02:21 PM
So the plan with John is: Get the heater fitted. Buy Helix 6 Paddle and fit to existing clutch housing Fit the Piper manifold I’ve had for months. Put decent brake fluid in. Two rear tyres. Drive it. Sent from my iPhone using Tapatalk
#725 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 19 January 2018 - 03:22 PM
Also - fit 3.1 pulley but this isn’t a priority Sent from my iPhone using Tapatalk
#726 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 19 January 2018 - 07:11 PM
Heater finished :)
#727 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 25 January 2018 - 11:56 PM
John has been an utter legend and has fitted the Piper manifold (after a bit of butchering :) ) and fitted the Helix 6 paddle and put it back together. I’m going across Saturday to help to hopefully get it finished. I’m blessed that John offers to help get my car back on the road or it would still be sat outside my house on axel stands. I’m actually excited to drive it again. I owe him a lot (of beer) and am also donating one of my knackered engines and standard manifold to him as the mad professor has some ideas to keep his hands busy. Sent from my iPhone using Tapatalk
#728 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 26 January 2018 - 10:33 AM
Prefer to say modify !  :D
#729 Talk-torque
Talk-torque
  • 150 posts
Posted 26 January 2018 - 01:41 PM
Well I just finished reading all of this Neil and have to admire you for sticking with it. Spec of the car now looks promising and you deserve a bit of luck with no more stupid dodgy earths and relays etc. Hope this weekend goes well and you end it with a great drive back home. Be good when we can all get together and put faces to names! You can give us some tips on the track, too, by the sound of things!
#730 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 29 January 2018 - 09:52 AM
Getting there now 6 paddle in and box in. I see too much even fixing cars so gone through a bag of cable ties getting everything tidy and reliable. Posted ImagePosted Image
#731 siztenboots
  • 26,613 posts
Posted 29 January 2018 - 11:12 AM
jubilee clips on gaitors?
#732 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 29 January 2018 - 01:28 PM
That’s from a fix I did at Zandvoort 2017 Sent from my iPhone using Tapatalk
#733 siztenboots
  • 26,613 posts
Posted 29 January 2018 - 01:52 PM
you were in the posh garages
#734 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 29 January 2018 - 02:02 PM
No garage - in the open air! Sent from my iPhone using Tapatalk
#735 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 06 February 2018 - 07:59 PM
John discovered the charge cooler pump wasn’t working. Probs hasn’t worked for a long time. This is why
He fixed it and filled up charge cooler but all coolant disappeared, but not externally. Turns out the o rings on the laminovas have dried out and perished so the coolant ended up in the intake manifold. So on Saturday it’s SC off, replace o rings, new relay and probs do pulley at same time.
I have what looks to be a 2.9” pulley from Lee so might fit that. However I need to know if I need an adaptor. It looks like this
Can someone confirm please?
#736 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 06 February 2018 - 08:02 PM
Is one of those screwdriver bolts loose mate ? We could do with some different bolts for Saturday of you have an engineering type place there ? Sent from my SM-G903F using Tapatalk
#737 CHILL Gone DUTCH
Posted 06 February 2018 - 09:46 PM
Take a measurement of the sc shaft and the pulley if it's a tight fit no adapter required If there's a difference a adapter is required
Take a measurement of the sc shaft and the pulley ( inside ) if it's a tight fit no adapter required If there's a difference a adapter is required
Edited by CHILL Gone DUTCH, 06 February 2018 - 09:49 PM.
#738 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 06 February 2018 - 10:07 PM
No they are all really tight. Haven’t got correct screwdriver head to remove. Will try local engineering place for bolts Sent from my iPhone using Tapatalk
#739 Acidpopstar
Acidpopstar
  • 3,556 posts
Cheers Sent from my iPhone using Tapatalk
#740 CHILL Gone DUTCH
Posted 06 February 2018 - 10:10 PM
The fact it's has bolt holes on it I would guess it needs a adapter
