could be an option. But that is another £1000 onto your build costs...
Saab B204 Conversion
#41
Posted 30 December 2014 - 12:09 PM
#42
Posted 30 December 2014 - 12:18 PM
if you use the 2L NA block , aka B206 , this is lighter as it is cast without the balancer shafts in the side , the shafts themselves are about 2.5kg each , plus the chain
Good information, would probably make sense, less to go wrong also.
I wouldn't spend £1000 on the Exige style cover, if there is nothing similar cheaper i'd probably look to just modify the existing one if needed.
I'd probably want to go charge cooler over intercooler so that's probably more weight added. Like I said before i'm not too bothered.
I have to say, I already like this forum, lots of information and everyone is friendly. I once signed up to an RX8 forum with the suggestion of an engine conversion. I had about 10 pages of slagging me off for even thinking it.
#43
Posted 30 December 2014 - 12:22 PM
I had the same thought about my RX8... but I think you would completely upset the balance of the car as the engine is completely different, however as a shell it's a great car with a w4nk(el) engine.
Anyway I digress. The coupe kits were available on here for a bit, think they were around £800, so plus spraying it'll be £1k easy. To be honest I think the edges of the hole in the clam for the boot lid will be as much in the way if it's too tall... at a guess I would say there is 1-2 inches of space above the top of the z22se block so the B204 would have to sit substantially higher
#44
Posted 30 December 2014 - 12:43 PM
#45
Posted 30 December 2014 - 02:32 PM
#46
Posted 30 December 2014 - 04:49 PM
I'm still sceptical of that t5 choice but admire his skillsChrist just do it. Old mate fitting the Volvo got the same grief about it being unsuitable and then turned out he was already fitting it after pages of people rubbishing his choice. I weigh an easy 40-50kg more than a lot of VX owners but does that make my car unusable?
#47
Posted 30 December 2014 - 05:44 PM
#48
Posted 30 December 2014 - 05:50 PM
#49
Posted 30 December 2014 - 06:07 PM
You don't sit over the rear wheels though.
I don't think anyone's saying the car will be unusable, but it's likely to negatively effect the handling. You could even argue that more weight up front improves the balance of the car. I think the advise and opinions made were useful and Escy has a bit more info for his build
#50
Posted 31 December 2014 - 07:51 AM
Edited by pete-r, 31 December 2014 - 07:52 AM.
#51
Posted 31 December 2014 - 01:36 PM
I take my car up the Brecon national park and mid Wales for drives and I can honestly say that for 80% of the time the SC makes no real difference to my pace. There aren't enough places which are straight and safe enough to deploy all the power, so with 400+ those opportunities would be even less.
I'm a bit surprised to see you say that, I go up there a fair bit and do a lot of "squirt and brake" on the twisties. Admittedly I usually go at 6 in the morning so there is next no traffic, but roads like the A4067 can lap up all the power you have as the visibility is so good.
Have you checked/considered a more suitable geo and/or some better rubber and wide wheels?
Edited by Nev, 31 December 2014 - 01:38 PM.
#52
Posted 31 December 2014 - 03:16 PM
Edited by pete-r, 31 December 2014 - 03:24 PM.
#53
Posted 31 December 2014 - 03:23 PM
#54
Posted 31 December 2014 - 06:00 PM
#55
Posted 31 December 2014 - 06:03 PM
#56
Posted 31 December 2014 - 06:14 PM
Who wants a fake 207?I have a forged b207 for sale if you're interested
#57
Posted 31 December 2014 - 06:17 PM
#58
Posted 31 December 2014 - 07:21 PM
To be honest if lee is serious about compound charging I would have thought that would be a good place to start no? Has it had liners done? Oh and ps those bits were here waiting fore when I got back - cheers!I have a forged b207 for sale if you're interested
#59
Posted 01 January 2015 - 12:04 AM
So he can just get different springs, dampers, etc and get it setup for the change in weight.
The Exige S2 has weighs more, has a battery mounted up high in the boot, an intercooler above the wheels way up high, a coupe back with more weight up higher yet no one complains about it's handling.
Edited by Bargi, 01 January 2015 - 12:04 AM.
#60
Posted 01 January 2015 - 12:18 AM
My turbo make 345lbft torque @ 3900. Id of thought the sc peak torque will be higher up the rev range?although with a better spread of torque?Also think of the delivery too because the sc torque is flatter but turbo torque will be higher at high revs.
