Hi I have a few items for sale listed below: (Note Cash on collection only from Uxbridge , Middlesex near Heathrow)
1 x Vauxhall Astra Gsi mk4 snowflake alloy wheel in silver, Good condition, few marks, tyre worn out and no centre cap. Part number is 13123257 , 7.5 x 17 ET47. ( £50)
4 x Vauxhall Astra Coupe 17" Turbo alloy wheels with centre caps, In need of refurbishment as slight curbing and paint flaking black over silver, Tyres not much tread left and 1 has wrong size tyre and it is a run flat tyre.( £100)
1 x Z20LET engine (head, block, exhaust manifold and turbo, inlet manifold, rocker cover). Came out of an Astra coupe, Requires rebuild but does run, didn't over heat when in vehicle and is still timed up.
Faults are: Started to smoke when at operating Temperature( warm) mainly after boosting up. So possibly combination of Rings, Turbo or stem seals etc,
Also Lower sump pan required as it currently has a damaged one on (leaking) I put on when removed this engine, also rocker cover has been painted black (not the best), And top cam belt cover is cracked and small oil leaks around engine, also level sensor needs refitting properly when sump pan replaced etc.
Ideally this engine would benefit from a rebuild to make a good engine hence why the cheap price (£200)
I have tried to upload photos like I used to but it does not work? I Have uploaded to photo bucket and tried copying and pasting here but nothing appears, so pm me to try and email photos if required.
Cash on Collection from Uxbridge Middlesex.
