Ideally you should look at sorting your brakes out before you fit a valve so they are working most efficiently in the dry. A valve is mainly there to allow quick adjustments when required (surface changes etc).
My car has one and at full forward it basically has no effect and gives me the original force of all four calipers. On full back it essentially turns off the rear brakes so only front locking is possible (for very slippery braking zones)
Cliffies car had too much rear bias IMO (I had a bit of a rear wiggle in the dry in it) but he had four pots all round and I believe it was set up with a plenty of rear bias as Mike liked it that way
Edited by SteveA, 07 January 2015 - 03:55 PM.
