Air Horn Wiring
54 replies to this topic
#1 Renny
Renny
  • 1,171 posts
Posted 09 January 2015 - 01:56 PM
I've added musical airhorns to my NA and they are superb (no really).. but...
I'm having problems wiring in the switch. I have wired exactly as shown in the diagram however regardless of which way I attach the wires to the horn switch and whatever position the switch is in the horns are on permanantly as soon as the connection is made between the battery and terminal 30/86 from the relay.
The connection is to a new switch by the way not the existing horn as I know that is illegal.
horn wiring
I've double checked all the connections and everything looks okay.
Any ideas? (Binning/wearing the horns etc answers are not required :dry: )
Thanks,
Renny
Edited by Rennywuk, 09 January 2015 - 01:58 PM.
#2 fezzasus
Posted 09 January 2015 - 02:19 PM
That wiring doesn't look right at all..
#3 fezzasus
Posted 09 January 2015 - 02:36 PM
The stereo earth might not be the same as the common earth as you'll get a lot of interference with the stereo if that's the case. I would move the horn switch earth to a different location. The earth for the airbag controller is one option.
#4 Renny
Renny
  • 1,171 posts
Posted 09 January 2015 - 02:40 PM
I am trying to avoid taking the dash off. Is this easily accessible?
Thank for your help.
Edited by Rennywuk, 09 January 2015 - 02:41 PM.
#5 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 09 January 2015 - 02:43 PM
please get a video
#6 fezzasus
Posted 09 January 2015 - 03:05 PM
I'd extend the ground and use an accessible grounding point to confirm that's the issue before trying to ground it on anything under the dash if you're avoiding taking it off.
#7 slindborg
Posted 09 January 2015 - 03:10 PM
the wiring looks fine to me.....
#8 Renny
Renny
  • 1,171 posts
Posted 09 January 2015 - 03:25 PM
I'll ground it somewhere else and test but is it possible the relay is fcuked?
#9 siztenboots
  • 26,612 posts
Posted 09 January 2015 - 03:32 PM
depends on how its wired
#10 slindborg
Posted 09 January 2015 - 03:36 PM
just be sure you have the pin numbers right :lol:
I did some repairs to a wiring harness on a car were the owner wondered why he needed two relays to stop the fuel pump.... I pulled the first one out of the relay holder to find that it didnt stop the pump :lol:
#11 Rudy
Rudy
    ZZZzzzzz.....
  • 3,375 posts
Posted 09 January 2015 - 06:40 PM
Air horn FTW :rolleyes: Sounds like Dixie Lee?
#12 Exmantaa
Posted 09 January 2015 - 07:19 PM
Your way of wiring makes the relay a bit obsolete...
#13 Renny
Renny
  • 1,171 posts
Posted 09 January 2015 - 08:52 PM
I ended up with la cucharacha Vid will follow once it works 😀
#14 CocoPops
CocoPops
  • 17,181 posts
Posted 09 January 2015 - 09:06 PM
#15 Rudy
Rudy
    ZZZzzzzz.....
  • 3,375 posts
Posted 09 January 2015 - 09:14 PM
Oh dear god :lol:
#16 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    motorsport especially BTCC
    rugby
    eating out
    keeping fit
Posted 10 January 2015 - 08:04 AM
Can't see the numbers but in my days of chav I ran a live direct from the battery to say the bottom terminal live to the compressor from top Then my switch was always an ignition controlled live to the relay which was earthed the other side This shouldn't really make any difference to your method but worth a try Have you tested the relay with a multimeter sounds like it could be stuck and you have a permanent connection between top and bottom connections also don't alwaysctrust the Chinese wiring diagram does the relay have a picture on of which terminals do what I have found in the past that the printed drawing dosent match the relay connections
Edited by christhegasman, 10 January 2015 - 08:19 AM.
#17 Renny
Renny
  • 1,171 posts
Posted 11 January 2015 - 10:29 AM
It seems my wiring would have been fine if using a grounded horn. As I'm not all that happened was the bridge between 30 and 85 meant the relay was burnt out and therefore of no use. I now have a correct wiring diagram but need to find an ignition live somewhere within the cabin. I'm trying to avoid taking off the dash. Any ideas? Thanks
#18 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    rugby
    eating out
    keeping fit
Posted 11 January 2015 - 11:40 AM
Bound to be an ignition live in the steering colum run the cable back through the bog grommet under the wiper motor No need to remove dash top just have to be able to stand on Ya head and have someone ready to pull you out my the feet when you get stuck 😀
#19 fezzasus
Posted 11 January 2015 - 12:17 PM
just take the dash off, it's only three screws.
#20 slindborg
Posted 11 January 2015 - 01:14 PM
I looked at the relay PIN numbers and there is no way the relay should burn out because of the bridgr(you need it)... Unless it was a sh*t relay
    Bing (1)
