So since buying my VX220 I've planned a good few mods and started a few already.
A little run down of the car where it was when I got it, where it is now, and what I have planned short term and long term.
I will update this periodically with pictures and details on what I've done,
This is how I've picked it up
- 127k miles 2.2 N/A
- Reasonable service history, brilliant up to last owner change really.
- Awful painted standard white wheels
- New disks and pads.
- Spax Suspension.
- Turbo spoiler
- A few other little bits and pieces
So upon picking the car up (Saturday afternoon), I noticed a few problems instantly. Before puchasing I'd noticed a slight bit water in the floor, the owner claimed it was from washing the car the night before (Have since resealed and no leaks)
After setting off I found out the heater did not work AT ALL.
Driving 5 hours from Birmingham to the north was chilly and my feet were freezing.
There is also an annoying rattle coming from the front. About 1/3rd of the way home The EML light came on, as well as the ABS light. Which prompted a stop on the hard shoulder, joined 30 seconds later by motorway police.
After a short conversation, and digging out the code reader we found that the car had had the EGR removed and the ABS seems to be from a bad connection to one of the sensors on the wheels. - More to come on that.
Eventually made it home and warmed up, feet eventually recovered feeling.
Sunday morning came and the first jobs were made
- Fix that damn heater
- Clear the water out of the inside
- Wash
- Good suspension and bearing check
So after finding the problem with the heater. The link pipe from the heater, to the inlet was almost non existent. Basically was a corrugated metal pipe with more holes and splits then anything else. Not sealed on either end and cold air blowing straight into the cabin.
With it being a Sunday, and me needing the car for work 6am Monday, I had to improvise.
This is the result
[Insert picture of heater "fix" here]
After measuring the Inside diameter of the heater outlet, and the cabin inlet, I realised that common drainpipe would fit snugly inside. So a full length of drainpipe and some bends later, the above was made, sealed together with some plastic cement, pushed tidily inside and just overly covered with tape for now. A better fix will be implemented in the future, but for now, works lovely.
Whilst waiting for the drainpipe to return, I had a helper strip the interior out and clean the inside. Below the seats we found some soggy chew sweets, a McDonalds chip in surprising condition given the amount of time it looks to have been there. And a CD. The wiring for the aftermarket speakers and sub was also raggy and badly done, so they got tidied up and run with the cars harness neatly and out of sight.
The crap got scraped up and cleaned, and the interior replaced.
The rest of the interior will be lined with Dynamat and carpet at some point in time to make the journey back and forward to work (some 50 miles a day) much more bearable. Shouldn't add much weight by the time its done, but will be a fair bit insulation.
This was followed with an inspection of the roof/door seal, to which several problems were noted, and some suitable cleaner and then glue were applied to return the seal to factory.
The evening finished with a very quick car wash, and an inspection of the paint and body work. All marks noted and checked against any work previously carried out. The decision has been made to re-paint the car in the not to distant future, rather than spend any time with the machine polisher cutting the paint and bringing back up a good finish.
Along with the rebuild will come an engine rebuild, full suspension overhaul and near enough a full nut and bolt rebuild of the entire car. Depending on funds at the time, some sort of forced induction will be added to the engine.
Anyway, back to the short term.
The headlights were deemed, for want of a better word, SH*T, and HID's were ordered for the low and main beam. 55W AC H7's and H1's should sort that problem out.
I pulled out the drivers side headlights, and managed to sort the HID's in no time. Passenger side wasn't as easy, pulled the light out to see no plug, only push together crimp connectors, and terrible ones at that.
So began the snowy re wiring of the plug.
Maplins provided for once and I purchased this to replace the plug.
I cut it down to a 6 pin plug once all the wires were in and done.
These will at least allow me to unplug the lights as and when I want.
Anyway, after an hour or so, the HID's were fitted, with the lights up and running
Some headlight covers will be sourced in the near future, I believe Fez's set available on eBay will be the most likely fix. I plan on painting the cluster anthracite, to match the wheels which will be painted shortly, before new lenses added.
So 2 weeks in, the car is slowly going through the changes required to bring it back to the standard it deserves. With many more "fixes" and modifications planned in the near future.
Next on the list, Order an Exige wing for it to hopefully stop that pesky back end sliding as much.
Hopefully the snow will stop so I can get to work in the morning.
thanks for reading the wall of text, pictures will be added in the next day or two where required, apologies for the size of the images, will re size soon, and the quality.
Edited by Dollon, 13 January 2015 - 08:03 PM.
