Harrop - What Pulley System
45 replies to this topic
#1 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 23 January 2015 - 05:11 PM
As the title says, need to sort a pulley system for the harrop for my car.
Any pointers on what to use. Hopefully from the states so I can pick uo next week?
G
#2 The Batman
Posted 23 January 2015 - 05:13 PM
they already have bolt on pulley modules so just whatever pulley you fancy
chinky chinky
#3 techieboy
Posted 23 January 2015 - 05:14 PM
Don't think you need a "system" as such. The pulley is just a bolt-on (like the modular system for the M62) as standard and not pressed on. So whatever size(s) you want from Smoothflow.
#4 The Batman
i win :P
#5 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 23 January 2015 - 05:16 PM
No Graham's Harrop doesn't come with a modular pulley on it.its a fixed pulley wheel .
Edited by leevx2.2, 23 January 2015 - 05:18 PM.
#6 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 23 January 2015 - 05:18 PM
Graeme just order a 2.5 inch pulley should work well :-) really though as Joe and Techieboy said its just a bolt on so decide how small you want to go and bolt it on now bearing pulley needed.
#7 The Batman
Posted 23 January 2015 - 05:20 PM
Did Graeme save a tenner buying this one? :lol:
#8 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 23 January 2015 - 05:21 PM
This might be a problem G man as on zzp you can't buy the part that is fitted to the charger .
#9 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 23 January 2015 - 05:22 PM
No allot more than a tenner ;-)
#10 NickB787
NickB787
  • 7,813 posts
Posted 23 January 2015 - 05:35 PM
interesting, got any pictures?.
#11 The Batman
Posted 23 January 2015 - 05:36 PM
Got a photo of the problem area? I can compare to a standard charger and it might be the same diameter so can use a normal module system
#12 CHILL Gone DUTCH
Posted 23 January 2015 - 06:15 PM
It's not the same
#13 CHILL Gone DUTCH
Well the pulleys them selves are diffrent
#14 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 23 January 2015 - 07:03 PM
Would the lotus part, that they use on the Exige v6 help? But yes as lee says, no pulley on mine. Savings a lot more than a tenner. Even if I have to spend a couple of hundred I'm still quids in. Don't want to though obviously. Harrop/TVS direct maybe?
#15 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 23 January 2015 - 07:04 PM
So it wasn't just me being stupid when I looked earlier then? If we can get an answer/idea in the next 24-36 hours I might be able to source it for when I'm in the States next week and save a load of time (shipping)
#16 The Batman
Posted 23 January 2015 - 07:19 PM
post a picture or atleast give us some info to work with :lol:
#17 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 23 January 2015 - 08:00 PM
I have no picture. My car is at lees, hopefully with the charger - maybe he can help with a pic? It came direct from lotus, so was either originally intended for an exige v6 or evora. Was used for testing in a dyno cell. Apart from that I don't really know anything about it. HTH �
#18 The Batman
Posted 23 January 2015 - 08:50 PM
ooo g man i hope a bespoke intake mani is being made?!
having done a few google searches, it appears the evora harrop has a bolt on pulley aswell
best bet would be measuring the shaft ( :lol: ) and then seeing if its the same size as the m62 one :)
#19 Exmantaa
Ehhhhh... Lotus tested the V6 with an "LSJ type" Harrop 1320TVS?? Or did you buy a Lotus type TVS that does not directly fit onto the LSJ SC manifold?? :unsure:
#20 Exmantaa
Posted 23 January 2015 - 08:51 PM
measure the diameter and check if you can mod an M62 modular hub.
It just needs a press fit tolerance.
Edited by Exmantaa, 23 January 2015 - 08:53 PM.
