Not LSJ type. We're making a new core plate, like lees to solve the manifold fitment problem though.Ehhhhh... Lotus tested the V6 with an "LSJ type" Harrop 1320TVS?? Or did you buy a Lotus type TVS that does not directly fit onto the LSJ SC manifold??
I have no picture. My car is at lees, hopefully with the charger - maybe he can help with a pic? It came direct from lotus, so was either originally intended for an exige v6 or evora. Was used for testing in a dyno cell. Apart from that I don't really know anything about it. HTH �post a picture or atleast give us some info to work with
Harrop - What Pulley System
#21
Posted 23 January 2015 - 08:52 PM
#22
Posted 23 January 2015 - 08:54 PM
#23
Posted 23 January 2015 - 09:17 PM
Yup as above, not lsj harrop. Still a 1320 TVS though afaikWhat Mr Mantaa said. I'd be surprised if Lotus used the LSJ 1320 TVS Harrop.
#24
Posted 23 January 2015 - 09:42 PM
#25
Posted 23 January 2015 - 10:39 PM
I have no idea if that will help Chris, but thanks for the offer. Having spent very little time even looking at the m62 or harrop I'm not even sure what I need etc.I can measure the shafts of both Harrop and m62 on Sunday if it helps The pulleys them selves have diffrent internal diameter where they sit over the modular bit
#26
Posted 23 January 2015 - 10:42 PM
#27
Posted 23 January 2015 - 11:01 PM
We definately need pics here...
But thinking out loud; Instead of bodging the pulley and GM throttlebody onto this TVS, is it not much easier to simply fit the Evora V6 under it in your VX??
#28
Posted 23 January 2015 - 11:04 PM
#29
Posted 23 January 2015 - 11:11 PM
Definitely looks like a pressed on pulley is standard on the Evora S' TVS
#30
Posted 23 January 2015 - 11:15 PM
#31
Posted 23 January 2015 - 11:23 PM
Is it possible that if you remove the pressed on pulley, the flange behind it is the same as used for the quick swap pulleys?
#32
Posted 23 January 2015 - 11:24 PM
Not now. What would have been easier would have been to not spunk a Fcuk load of money on forging the Saab engine and just fit the m62 instead. Cnutsticks So we need lee to confirm with pics of charger etc?We definately need pics here... But thinking out loud; Instead of bodging the pulley and GM throttlebody onto this TVS, is it not much easier to simply fit the Evora V6 under it in your VX??
#33
Posted 24 January 2015 - 12:18 AM
Why would you spend money in forging a Saab engine, as it's pretty stout with stock internals..
#34
Posted 24 January 2015 - 12:58 AM
#35
Posted 24 January 2015 - 08:01 AM
The bad thing aswell is on the v6 no charge cooling in any way :-(Definitely looks like a pressed on pulley is standard on the Evora S' TVS
#36
Posted 24 January 2015 - 11:12 AM
#37
Posted 24 January 2015 - 11:15 AM
#38
Posted 24 January 2015 - 11:18 AM
#39
Posted 24 January 2015 - 11:32 AM
Shamelessly stolen from other threads on here:-
Unfortunately, no pics without the Evora/Exige inlet manifold attached but looks like a longer snout and the actuator is in a totally different place
Humongous inlet from the throttle body though
And the LSJ TVS (and the M62) for casing comparison:
#40
Posted 24 January 2015 - 12:06 PM
Why not?I haven't got Harrop
