don't worry about installing the hands free.. you cant hear anything over 30 mph
I've Joined The Club- Silver 2001 Vx220 Tinkering Project.
#81
Posted 12 February 2015 - 01:37 PM
#82
Posted 12 February 2015 - 10:33 PM
No point at all covering the ducting in silver tape. By that point the heat is already where you want it (cabin) and the amount of heat loss through radiation is minimal. There are better ways to spend your time/money.
Cost fcuk all as tape is in bag fulls in the work van, time took 5 mins. Was having it apart to clean so might as well. Job done.
#83
Posted 12 February 2015 - 10:34 PM
Want it for music mainly and it was laying around spare. Issues getting it to work now though as lost lead in box and only have mazda adaptor from the old car.
Got it wired in and powered but dont hear it over speakers.
#84
Posted 12 February 2015 - 10:37 PM
Is that a spout from a tube of super glue by the locking wheel nut grommet? I'll be interested to see what you come up with for the bonnet struts, it's something I have thought of doing in the past but never got round to.
Nope its a proper piece of plumbing that came with the washer wiper kit.
I've got a plan. Its on my long list of projects!!
#85
Posted 12 February 2015 - 11:02 PM
This may well be down to it being set up to output over front speakers only which won't work in the VX, are there settings you can adjust to change this? If not it should be easilly sorted by either adding additional speakers near the sill pockets / in dash or swapping over a couple of wires in the ISO cable.Got it wired in and powered but dont hear it over speakers.
Edited by -Dab-of-Oppo-, 12 February 2015 - 11:04 PM.
#86
Posted 13 February 2015 - 12:17 AM
ahhhh Ive got a parrot system and match mute. good point re speakers! Ill just play around with the ISO cable for now! Thanks!
#87
Posted 14 February 2015 - 11:11 PM
Gave up with the parrot system in the end.... just wasn't loud enough with the existing cheap stereo unit maybe lack of ampfliying and what not.
Ended up joining the dash speaker club, I had to cut the foam to fit these 4" ones in but I am happy. I also made the heater box channel smaller so as to not waste heat where the speakers now are
Here it is installed with new stereo that has the handfree built in
Thanks to Barton, I have been able to complete the look of my dash, the switch surround was a scuffed tatty silver whilst the dash had a carbon panel- the sets complete now
Finally after waiting for them to arrive- obligatory stick on pockets for the lady ;-) and same on my side as well!
Dash is back in, and hope to have a little drive/hoover and clean tomorrow before mods round two commences.
Round 2.
4x USB power sockets
Boot light and switch to control coming on with opened lid
Cargo net
Battery support OEM bracket fit
Corrosion treat under seat floor area
#88
Posted 15 February 2015 - 09:48 PM
Cargo net achieved. Yes it's big, yes it's not OEM but its big enough for mine & passengers needs so that is all that matters.
LED boot light was accomplished, this photo was before I routed and tidied cables and reinstalled carpet. I am going to change the switch as this one is a bit intermittent when opened. I took a 12v feed from cigarette socket, drilled new hole with rubber wire hole grommet near the boot release cable...was a slight panic when I thought I had drilled the fuel tank but was fine when the stiff wire guide was visible!
Having to use a bigger prop to get the height, I am now keen to look into a gas strut lift...
I also got my ACF-50 corrosion spray down under the seats whilst they were out. I have some rear sound proofing from Deroure for under seat and rear slope.
Downside was the already cracked sill cover took some more damage...will repair this before considering replacement.
To do-
Alloy stalks
Repair sill cover
Edited by karlb123, 15 February 2015 - 09:50 PM.
#89
Posted 16 February 2015 - 01:40 PM
poodling along nicely.
#90
Posted 18 February 2015 - 12:17 AM
Tonight whilst charging battery I did the following-
Installed my handsfree mic here as it was only place it would clip on and its in direct mouth shouting distance haha
Fitted my alloy stalks
Found two rubber grommets to replace missing ones
Installed fire extinguisher
And I am really chuffed with my boot light. I will really help on the dark nights getting weekend bags in and out
#91
Posted 19 February 2015 - 08:34 PM
#92
Posted 19 February 2015 - 08:50 PM
#93
Posted 19 February 2015 - 08:57 PM
#94
Posted 19 February 2015 - 09:16 PM
That boot light is a good idea. Have you got it activated by the boot lock alarm sensor?
#95
Posted 20 February 2015 - 01:25 AM
Its switched by its own switch in the same locale as the boot lock alarm switch :-)
What I will add now is electronic boot release so that the current release isnt abused when the car is left with the roof off! Hidden button to open boot.
Karl
#96
Posted 20 February 2015 - 08:08 AM
#97
Posted 20 February 2015 - 08:18 AM
#98
Posted 20 February 2015 - 10:57 AM
GooDo work Karl. I'd not bother with the battery support, they said it couldn't be done!
Battery or boot support?
#99
Posted 20 February 2015 - 10:58 AM
Unlikely that any opportunist thief would have any idea where the boot release lever is on a VX Karl. It's already very well hidden. By the way......you're clearly far too skilled for the NPC.
That is true but any lil sh!t can pop out their smart phone and google these days! Plus I want the option to connect the mechanical release into the potential future wireless keyfob boot release with gas struts.
#100
Posted 20 February 2015 - 11:09 AM
Battery!Battery or boot support?GooDo work Karl. I'd not bother with the battery support, they said it couldn't be done!
