Battery!
Battery or boot support?GooDo work Karl. I'd not bother with the battery support, they said it couldn't be done!
I've got an OEM one to fit soon, being delivered by one of the NPC brothers from the NPC warehouse.
Posted 20 February 2015 - 11:23 AM
Battery!
Posted 24 February 2015 - 12:08 AM
Got hold of a OEM bracket and fitted it, annoyingly 1 of the 3 bolts captive nuts was spinning so I had to chop the head and use this as a 2 bolt and 1 positioning stud setup.
I also afixed some L shape corner bracing at the bottom of the battery on side where the +ve terminal is near the chasis and poses a risk if the battery cap cover is freed and battery should slide.
I also did my first vinyl wrap! I picked the easy centre tunnel.
The console, cup holder and door cards are away being sprayed up currently so thought id take a go at wrapping-
In progress
Finished and I am very happy. I plan to make a small test wrap and see what happens if lacquered!
That is all for now!
Posted 24 February 2015 - 09:29 AM
Get yourself a rivnut tool (like this: http://www.ebay.co.u...=item5d52355f0e) and some zinc coated M6 rivnuts and replace the spinning one.
Posted 24 February 2015 - 10:42 AM
Thanks for the tip Fez. Paypal coming you way shortly!
Karl
Posted 25 February 2015 - 12:20 AM
Did some more wrapping tonight, this was a tricky part!! Not 100% perfect and I nearly binned it but looked better once fitted
Fitted
Posted 25 February 2015 - 01:51 PM
To do list - updated.
Window rattle mod
Alarm LED repair
Electric boot release hidden button for security when roof left off parked
Gas strut for boot
Vinyl wrap window surround
Respray door cards
Respray centre console
Respray cup holder
4x USB power sockets
Fezz heater
Soft top roof lining
Battery support OEM bracket fit Improve by fitting M6 Rivnut to replace spinning nut.
Repair sill cover 2nd attempt needed with added glass fibre reinforcing and then respray or leather sill covers
Posted 25 February 2015 - 09:16 PM
More wrapping again!
These were easier to wrap than the door pillar triangles!
Ther
Window rattle mod
Alarm LED repair
Gas strut for boot
Respray door cards
Respray cup holder
Fezz heater
Posted 26 February 2015 - 11:48 PM
Thanks to a brother from the NPC MASSSIVE my windows no longer rattle! It is in my opinion the best, quickest and cheapest mod you can do!
Thanks Ken!
Alarm LED repair
Gas strut for boot
Respray door cards
Respray cup holder
Fezz heater
Posted 27 February 2015 - 07:52 AM
Posted 27 February 2015 - 03:12 PM
Who has a Fezz heater and is it worth it? I laid out a small fortune on the 23rd to Tom/Fezz for some of his remaining parts so I can assemble one.... can't wait to get the parts...
Posted 27 February 2015 - 03:51 PM
Posted 28 February 2015 - 11:22 AM
its much better then standard, although I don't have one.
Its the best of a bad situation, there are a lot of things that conspire against a heated vx... the massive heat dispersing chassis for a start
Posted 28 February 2015 - 11:38 AM
Ah yeah...sitting in a giant aluminium heat sink!
Posted 28 February 2015 - 02:53 PM
wrapping
Posted 28 February 2015 - 07:08 PM
My car, ill wrap what I like until I can afford real carbon until then wrap away!
Posted 28 February 2015 - 09:54 PM
Posted 28 February 2015 - 10:26 PM
OllyJ isn't a fan of wrapping but then again he lost his NPC voting rights on my car when he ripped the clam off! haha
Posted 01 March 2015 - 12:17 AM
How do you remove these Karl?More wrapping again!
Ther
[color=rgb(40,40,40)][font=helvetica]
Posted 01 March 2015 - 08:30 AM
Posted 01 March 2015 - 09:35 AM
