The Darkside Project
2139 replies to this topic
#2001 Nev
Posted 01 January 2019 - 02:35 PM
So my ewp has a controller, you set the temperature you want and it will turn on / off keeping it at the desired level, this eliminates the need for a thermostat (less weight :lol: )
It also has an external led that can be fitted anywhere and if the pump fails then this will light up.
Ah great, a bloody big light on the dash to tell you to stop driving would be useful. If I ever re-wire my car I'd do something like this.
Will your pump controller vary the voltage/current though, that's where you'd make the best savings on power drain IMO.
I suppose a similar concept could be applied to fuel pumps too, as they pull a lot of amps. You'd have to map accordingly of course, and it would work like a rising rate/dynamic FPR, but with a stronger rising rate.
The reality is though, when you are driving fast/flat out, your car is going to need close to max cooling and max fueling... (ie both pumps working hard).
Edited by Nev, 01 January 2019 - 02:40 PM.
#2002 M111
M111
  • 10 posts
Posted 01 January 2019 - 03:06 PM
I know bud my comment was to shut the haters up :lol:
I hope that wasn't aimed at me?
I'm not hating on it at all, its an interesting project, just pointing out its not quite the miracle "no parasitic losses" you might of thought.
There's no doubt there's benefits to be had from these setups, most of them you have already mentioned but there's also a plenty of negative points that you probably haven't considered.
Just don't expect noticeable power gains as you might be disappointed......
Edited by M111, 01 January 2019 - 03:06 PM.
#2003 M111
M111
  • 10 posts
Posted 01 January 2019 - 03:29 PM
They're not worse Joe if they run properly.
Your belt driven water pump's rpm is fixed to the engine speed which is not ideal for cold starts and different operating conditions. Your engine's thermal efficiency increases with rpm and load so it doesn't make sense to increase the rpm of your water pump at a fixed rate with the engine as it will be spinning too quickly. I can't see why you would need a thermostat with an electric pump either.
But I'll warn you about Davies Craig pumps as I've heard they're not very reliable.
Good points, the main one being "if they run properly". I've heard about a few in elise's & yet to hear of one that works anything like it should.
Yes the mechanical pump will end up working too hard at high RPM because it has to be able to pump enough at lower RPM, I would have thought the pressure relive valve in the thermostat bypasses a lot of that excess pressure so the pumps not having to push quite as hard as it might otherwise have too.
A couple of points worth considering taking this engine as an example, it should be producing considerably more power (heat) than what the OE pump was designed for & secondly the coolant circuit of these cars is a lot more restrictive than a Civic, so you would actually need a bit more flow & pressure behind it than would be necessary in the standard Civic it was designed for.
All just IMO of coarse!
Edited by M111, 01 January 2019 - 03:33 PM.
#2004 The Batman
Posted 01 January 2019 - 03:53 PM
As said the power gains have been seen and spoken about for a long time as this engine is getting on a bit now so a lot has been tried and tested. I like info though so thanks for that but I also like to see data
I’m more happy about the track benefits this pump can give me and if I gain a couple hp and rev a bit quicker then that’s great and just what I’m after
I think I will spend the evening in the garage doing a few bits and bobs and tidy the garage up
#2005 M111
M111
  • 10 posts
Posted 01 January 2019 - 05:13 PM
I also like to see data & don't get taken in by BS.
Could you point me in the direction of some genuine test results that are not generic, from pump seller or a half arsed test by some Yank on a forum?
I've seen one but don't think it was done very well because they left it too long between dyno runs, makes me think the pump had slowed down by then & probably didn't kick in again until after the short 5 sec power run. Its a bit like giving it a rev in neutral & saying it picks up quicker but that's because there's no load on the alternator due to he pump not running at full chat.
#2006 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 01 January 2019 - 05:14 PM
Joe is also running it at the front in an easy place to change but also just after the main rad so the water running through it will be at its coolest.
 Hopefully meaning a longer life.
#2007 The Batman
Posted 02 January 2019 - 12:13 AM
did a bit more tidying up today, finished off the battery compartment and fitted my charger cable (only had it a few years lol)
fitted the 2 strut braces for the splitter
trial fitted my spare pump, and this is where it will go once i've got new hoses
mocked up where my oil cooler will be going and plumbed the coolant line:
also fitted the new rear silicone hoses
tempted to go back out there, just having a cup of tea :lol:
#2008 The Batman
Posted 02 January 2019 - 09:40 PM
well the plan was to achieve a bit more than i did today :lol:
so i wanted both my guages to look the same, so first i only had a tripple gauge holder so got rid of that (so if anyone needs one let  me know its to replace stereo)
this is what they started off like:
as the aem comes with a silver facia aswell, i decided to spray them both matching colour, then had to sand back the silver gauge so that it would fit and then i will glue in place when the new twin facia plate arrives :)
#2009 CHILL Gone DUTCH
Posted 03 January 2019 - 09:59 AM
What is the gauge
#2010 The Batman
Posted 03 January 2019 - 10:42 AM
Wide band and oil temp
#2011 CHILL Gone DUTCH
Posted 03 January 2019 - 11:54 AM
have you had oil temp isues ??
#2012 The Batman
Posted 03 January 2019 - 12:32 PM
I dunno only one way to find out lol
#2013 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 03 January 2019 - 02:56 PM
I’m having one in mine that’s why Joes got one 🙄
#2014 CHILL Gone DUTCH
Posted 03 January 2019 - 04:49 PM
Sounds like a worry gauge
#2015 The Batman
Posted 03 January 2019 - 11:37 PM
That’s all gauges are!
Fitting them on stereo so pax can worry about it
#2016 1cobrav8
1cobrav8
    Joe is faster than me
  • 516 posts
Posted 10 January 2019 - 07:27 AM
That brake duct looks like it will foul on the water pump....
Needs an engine also, but still quicker than mine
#2017 The Batman
Posted 10 January 2019 - 07:39 PM
front end is all back together now :) and back on 2 wheels (well 8 as its on 2 skates :lol:
just waiting to collect my bonnet which ive had a slight tweak done to it ;)
#2018 MAXR
MAXR
  • 2,719 posts
Posted 12 January 2019 - 08:38 AM
Joe, tell me, will this setup make you go faster!!!!!! Lol.
Or will the elec pump still hold you back from your full potential! Lol
#2019 The Batman
Posted 12 January 2019 - 08:43 AM
The electric pump will put me on the grass!!
#2020 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 12 January 2019 - 03:07 PM
It’ll kill his alternator and he will go through many many lithium batteries 😄
