The Darkside Project
2139 replies to this topic
#2061 siztenboots
  • 26,613 posts
Posted 09 February 2019 - 09:06 AM
not from Jim I hope
#2062 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 09 February 2019 - 08:11 PM
Six month lead time isn’t bad 🙄
#2063 Arno
Arno
  • 1,238 posts
Posted 11 February 2019 - 09:41 AM
Do any OEM's use a twin inlet port rather than a siamesed port? I've seen it on aftermarkets or exotic race heads but it doesn't seem to be adopted.
Has been done in some form like Vauxhall/GM used it on their twin-port engines in the Corsa's and the like.
Usually have to 'cheat' a little though as they tend to want to use a single injector, so often the two runners do share a single injector in case of a traditional port-injection setup using a section where the two runners have a shared 'raised roof' section. (direct injected engines like some of the CDTI's do have 8 intake ports on the head)
Toyota (and others) have used manifolds in the past with separate runners, often with butterflies/valves in 1 runner to increase air velocity at low load in the 'open' port/channel in the manifold (eg. TVIS system on 3SG(T)E engines).
Mostly done for fuel economy by OEMs at part-load to increase air velocities in the intake port and improve air-fuel mix in the combustion chamber.
Honda's VTEC-E system on the more eco-based engines does a similar thing by keeping 1 of the intake valves closed during part-load (so running it as a 12V engine) and switching to 16V mode in higher load conditions. This gives the same general result but does away with complicated manifold constructions with 8 runners or extra flaps.
#2064 The Batman
Posted 12 February 2019 - 01:20 AM
some lovely valves
balancer delete and new z4 oil pump
engine looking like an engine now!!
#2065 gaffer1986
gaffer1986
  • 4,408 posts
Posted 12 February 2019 - 09:13 AM
Looks so clean!
#2066 The Batman
Posted 12 February 2019 - 10:32 AM
Yeah! All been blasted and bolts been replated :wub:
#2067 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 12 February 2019 - 09:12 PM
Is it in yet?
#2068 The Batman
Posted 12 February 2019 - 09:18 PM
Na, hit a bit of a hiccup with the sump not fitting the latest spec pump so getting a new sump
Waiting on modified cam cover aswell
#2069 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 13 February 2019 - 05:32 PM
What kind of modification on cam cover?
#2070 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 13 February 2019 - 05:34 PM
Is your cam chain top giud updated? I know I bought a longer (wider) version of this for my Engine
This is to prevent any jumping change atleast on the camgears.
If you want I can see if I still have this partnumber somewhere.
#2071 The Batman
Posted 13 February 2019 - 05:59 PM
Chains where genuine honda parts
Cam cover is having extra 2 breathers fitted to it :)
#2072 Nev
Posted 17 February 2019 - 07:21 PM
Some chav has got into your garage and painted the bolts green!
#2073 The Batman
Posted 17 February 2019 - 07:30 PM
He’s trying to slow me down to his level
#2074 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 17 February 2019 - 10:21 PM
Not the chain the chain guid over the cam gears. There is a geniune later honda but its longer.
Do you want the part number?
#2075 The Batman
Posted 17 February 2019 - 10:29 PM
yes please bud
i take it, it is a worthwhile mod?
#2076 CHILL Gone DUTCH
Posted 19 February 2019 - 06:07 PM
along with the rotrex
#2077 The Batman
Posted 19 February 2019 - 06:38 PM
If i bought another rotrex then it would be sold like the last one... baby is destroying everything already. :lol:
#2078 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 22 February 2019 - 05:12 PM
I thought I had the part number stored but cant find it. But I Think it´s the one used on the later Type R FN2 (k20z4) seen below.
Called cam chan guid B.
cost aroud 20 usd
https://www.ebay.co....A-/302878015343
https://www.hybrid-r...ine-build-guide
yes please bud
#2079 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 22 February 2019 - 06:15 PM
Is it finished yet?
#2080 The Batman
Posted 22 February 2019 - 06:28 PM
Still waiting for the sump :(
