The Darkside Project
2139 replies to this topic
#2121 The Batman
Posted 30 May 2019 - 06:56 PM
the eagle eyed few may see a few more mods done to it ;)
here is a few more pics from the build
cc rad fitted
chargecooled intake manifold
photo of the cc
probably a load more photos i havent updated but you get the idea ;)
#2122 The Batman
Posted 30 May 2019 - 06:57 PM
Rough update on the spec
So to some up roughly the spec..
Custom oversized 2.2 10.7:1 JE pistons
Carillo rods
Darton sleeved z4 block
water pump delete
Balanced shaft delete
Upgraded oil pump and sump
Clockwise baffled sump
Jdm cams
+1mm valves
Supertech valve springs
Balanced bottom end
Ported head
Lightweight flywheel with upgraded clutch
2bular 4-2-1 exhaust system
Gearbox 5.1 FD (will be interesting lol)
Quaife lsd
Kpro4 ecu upgrade
Oh and 132 tvs charger with a chargecooler intake manifold 🙂
Maybe some other bits I’ve forgotten 😂🤣
#2123 tommobot
tommobot
  • 1,008 posts
Posted 30 May 2019 - 07:33 PM
Christ! That will fly!
Not running a bulkhead heatsheild?
#2124 Exmantaa
Posted 30 May 2019 - 08:07 PM
Haha, I remember you saying not too long ago that the Honda will not get supercharged.
The SC Force is strong...  :ninja:
#2125 Exmantaa
Posted 30 May 2019 - 08:19 PM
Ehhh, 5.10 final drive gearbox on a supercharged 2.2?? Hope the shifting is quick...
When will it go on the dyno?
#2126 The Batman
Posted 30 May 2019 - 08:50 PM
Na, never did last year either, i hate gold tape..
haha yeah.. i couldnt resist in the end
To be honest, i reckon i am the quickest shifter in the west :lol:
but yeah if the 5.1 is too much then i will look at my options, 4.7 is still on the shelf (original FD)
Not booked in yet, still a few things to do to inside cabin and at front... going to make the arches and diffuser standalone aswell
#2127 Firthy
Firthy
  • 576 posts
Posted 30 May 2019 - 09:21 PM
What a weapon 💪 Cant wait to see some vids :)
#2128 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 30 May 2019 - 09:35 PM
It’s going to cut that grass sooooo fast 😉
#2129 The Batman
aslong as it doesnt go any further than grass :lol:
#2130 vocky
Posted 31 May 2019 - 09:49 AM
that is a very neat install thumbsup
#2131 Arno
Arno
  • 1,238 posts
Posted 01 June 2019 - 06:53 AM
Quite..  B)
1st gear on a Honda install in an Elise with the standard FD is already pretty useless in many cases.
1st gear on an SC/ed Honda is becoming pointless (people on these often start out in 2nd and don't use 1st)
1st gear on this torque monster with a 5.1 FD will likely either just smoke the tyres or need to shift up in about 0.2 seconds as the rev needle whips around  :rolleyes:  (also I suspect it's top speed is going to be maxed by hitting the rpm limiter and not the aero drag..)
IMHO this car would be a perfect candidate for the 3.9 FD that Gaz made for the Honda's a while back. Usable 1st and by playing with the gearsets from the EU/USA and JDM boxes you can make a close (JDM) 2-3-4-5 with a long/overdrive (EU) 6th.
Still.. Very nice install and with the current gearbox setup it should really feel like a monster and pull like a madman in any gear.  thumbsup  (I'd almost say it could be a pretty scary car in less nice weather conditions.. TVR-esque almost.  :D )
#2132 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 01 June 2019 - 04:30 PM
I agree with Arno, why making the gearbox shorter, specially with this much Power.
Didn´t you have a rotrex kit? why go for the TVS instead of the Rotrex?
Br, Per
#2133 The Batman
Posted 02 June 2019 - 11:40 PM
I really don’t care how short 1st gear is to be honest lol I don’t drag race and first will be used for getting off the grass on track 😂😂😂
It will be a dry weather only car :)
This reminds me I have jdm 4/5/6 aswell thumbsup :lol:
Yeah I had a rotrex kit, but sold it to help pay for new house, then this new kit turned up for sale so snapped it up
#2134 Arno
Arno
  • 1,238 posts
Posted 03 June 2019 - 12:40 PM
Hmm... JDM 4/5/6 AND a 5.1 FD..
Based on 225/45R17 rear wheels you'd do:
240 km/h at 8000 rpm in 6th.. Yeah.. You're definitely not aero limited, although you could try to make it so with massive splitter and wing as you have a massive SC backing it all up :D
57 km/h at 8000rpm in 1st though :o
#2135 The Batman
Posted 03 June 2019 - 10:52 PM
35mph in first isn’t bad tho lol
And 150mph top speed should be enough for track!
Am tempted to rev it higher tho but will see what the power is like top end
A bigger splitter has always been on my mind
#2136 Rosssco
Rosssco
  • 4,183 posts
Posted 04 June 2019 - 07:27 AM
The 5.1FD is great for towing. Dont listen to the haters!
#2137 The Batman
Posted 04 June 2019 - 11:24 AM
:lol:
#2138 The Batman
Posted 12 July 2019 - 09:46 PM
cracked on with this, this week. So wired in both the water pumps, fitted a standard 063 battery as the 680 oddesey one died :rolleyes:
modified throttle cable linkage to hopefully make it smoother
fitted standard seat frames to my reverie seats
also modified the rear arch liners, so these now dont have to be removed when removing the rear clam B)
Then the next step was the engine.... FINALLY
so power on, checked error codes - NONE! result.
left plugs out and cranked over to build oil pressure, fitted new plugs and turned the key... started first time, cant be happier than that! Which i wasnt expecting to be honest as i am still running the ITB map!
the jobs left to do are:
modifiy undertray for the larger sump, hoping can just space it..
Then i want to cut the rear 'bumper' so that i can leave the diffuser on when removing the clam, this way would just be the exterior bolts and the 4 spoiler bolts and the clam is off... not that im wanting to have to take it off!!
#2139 hairy
hairy
    Moonlander
  • 6,028 posts
Posted 12 July 2019 - 09:59 PM
Dude, I really dont know how you fit family life around all this. Respect Imnotworthy .
#2140 The Batman
Posted 12 July 2019 - 10:02 PM
sprog isnt born yet lol
3.5 weeks to go! but little shit is why this has been delayed as had to re-decorate the house :rolleyes:
but after the weekend the car should be ready for mapping but RLM Racing is very busy so waiting game, but to be honest there is no rush now i dont think... will stick it on its wheels and drive it out the garage for a clean tho :D
