The Darkside Project
#221
Posted 26 March 2015 - 02:57 PM
#222
Posted 26 March 2015 - 03:59 PM
Isn't the K20A a 'productionised' version of the S2000 F20C motor?
If so, what differences are there between them that allows ~240bhp vs. ~200bhp?
#223
Posted 26 March 2015 - 04:06 PM
#225
Posted 26 March 2015 - 09:38 PM
The K uses VTC and the F doesn´t.
The F is much more tuned, with some candy I consider the K ´to be just as good.
#227
Posted 27 March 2015 - 10:19 AM
#228
Posted 27 March 2015 - 10:24 AM
ooh that really is nice Joseph!!
#229
Posted 27 March 2015 - 10:29 AM
No. The F20C is design-wise more like an intermediate engine between the previous D-, B- and H-series engines and the later K-series.
The F20C lacks the cam-timing adjustment (VTC) and only has the profile switch (VTEC) which is the cause for it's less-than-stellar torque at lower rpm's.
In this respect it's more like the B/H-series engines, but it does rotate clockwise (older Honda engines ran were counter-clockwise) and the block and head design follow the same general design as the later K series engines. Various parts are interchangeable between the K and F series with sometimes some minor modding. Various K-series parts are often used by S2000 owners to improve the engine.
Revs
Heads are fairly similar when it comes to shapes of chambers and ports/channels. OEM Intake manifold on the F20C is actually not that great.
However.. The F20C is a slightly larger bore and shorter stroke (87x84mm) than the K20 (86x86mm) so it allows the F20C to safely run up to 9200rpm in stock form.
As BHP is simply a function of revs+torque, as the revs rise and you can keep the torque at a reasonable level then the result is a higher peak HP. F20C also came with a good/long exhaust manifold and decent exhaust routing. K20A standard enxhaust manifold is pretty short/compromised in comparison.
Also, the K20A2 in europe and the US was limited to 7800 rpm and rated at 197HP while the Japanese K20A ran 8600rpm and around 225 Bhp in stock form.
Not really sure why as the're very little, if any, construction difference between the K20A and K20A2 apart from some minor detals like slightly higher compression (11.5:1 vs. 10.5:1) and a tad wilder cams on the JDM K20A. Probably an emission/marketing/something reason
It's not too hard to make the K20A2 generate between 220-240HP in N/A form with good intakes and exhaust setups combined with a little more agresisve cams.
Also it's a very different experience drving a K20 compared to an F20C as with a Hondata equipped OEM ECU (or a standalone ECU) you can map and set up a K20 to have a load-dependent VTEC switchover which, combined with the VTC cam angle adjustments, makes it a virtually seamless switch to the 'wild' cam profile and no longer the 'VTEC yo!' *bump* of the older engines. This makes the power band very wide and it pulls smooth from idle al the way to the rev limiter.
#231
Posted 27 March 2015 - 12:12 PM
Good answer (as usual)..
#232
Posted 27 March 2015 - 01:26 PM
Thanks for the info dude
Tb and rrc adaptor plate turnt up today
TB seems a little incomplete? Missing the TPS at the side and idle control valve at the bottom. Also still seems to have the second cable wheel for cruise-control on it. (probably not from an EP3 typeR?)
I want to get the inlet and outlet bored out. Will any machine shop so this for me?
Decent machine-shop should be able to help you.
OEM TB's can't be bored out too much as there isn't very much 'meat' in some parts.Usually the butterfly can be brought to 64mm and the housing tapered from the ends starting at 70mm.
RRC manifold should be no problem to bore the intake connection to 70mm. Little or no channels in it.
I see your RRC is not modified for the older engine style yet (K20A). Usually the water outlet connection that's integrated in the flange on these (for the later K20Z engines) needs to be cut off for the older engines as they have a separate outlet spout attachment and not integrated in the manifold.
#233
Posted 27 March 2015 - 09:32 PM
#234
Posted 28 March 2015 - 07:43 AM
#235
Posted 28 March 2015 - 02:59 PM
Guy in my area runs a K24 with 357 bhp N/A...... Sounds like a motorbike and runs like a beast. Should be awesome in a VX!
No idea how long it'll last...
with respect, that's total fiction (assuming it's running on petrol), head/87mm bore just can't flow that much, period.
No, as Arno said, different generation of engine.
F20C has 'better' head port design (all 100% symmetrical etc), but lacks VTC, and because of the port design, it's more bulky.
Power wise, F20C can make more power in std trim, but it's only in the last ~800 Rpm, K20A is all over it up to that point.
#236
Posted 28 March 2015 - 05:38 PM
No worries mate, it's not my car nor am I really connected with these guys. All I know is they spend shitloads on Honda stuff and make serious N/A power. Previous engine did 297 bhp but ended up in pieces. He build a new one and pushed 357 bhp. Car is not roadlegal anymore I've heard. Check out their facebook site for more info "0118 racing"
https://www.facebook...8racing?fref=ts
Grtz,
#237
Posted 28 March 2015 - 06:39 PM
Appreciate that,
it's simply not credible though, 357 HP at the crank would require a K24 at 8,000Rpm running some 135+% VE
that is simply not credible, the very best NA race engines might approach ~110-115% VE (and by best I mean purpose designed stuff, not re-worked production)
to get to 135% you're usually looking at forced induction in the 10-11+Psi boost range.
(I await the inevitable dyno plot!)
#238
Posted 29 March 2015 - 09:45 AM
Appreciate that,
Well a friend of mine in the Swedish Hondaclub is not havig 357 bhp but a respectible 331 bhp NA and this with std port size and OEM RRC manifold. A full CNC head bigger valves and a Skunk 2 Ultra manifold with spacer or any other good manifold. And those numbers shouldn´t be too far away. This is on E85. + There are more candy you could bring on.
http://rejsa.nu/foru...r=asc&start=294
BR, Per
#239
Posted 29 March 2015 - 01:25 PM
BR, Per
Also not very credible, although he is running E85 not petrol.
8,000+ Rpm on a 99mm stroke is also pretty risky, (piston speeds exceeding that of the old V8's in F1 doing 20K+ Rpm)
I can believe he's at ~300hp levels, maybe a tad more, and to be fair, his torque figures look reasonable realistic, my guess is the dyno's being unrealistic higher up the rev range.
#240
Posted 29 March 2015 - 07:28 PM
