The Darkside Project
#341
Posted 22 August 2015 - 06:34 PM
#342
Posted 22 August 2015 - 06:35 PM
if i was you Joe if you have bought them change them
#343
Posted 22 August 2015 - 06:41 PM
Agree with Lee.if i was you Joe if you have bought them change them
#344
Posted 22 August 2015 - 06:42 PM
#345
Posted 22 August 2015 - 06:44 PM
Master cylinders in my experience sometimes you leave alone the seals will recover, but then give them some sh*t and they will start leaking and letting fluid past so no more brakes
#346
Posted 22 August 2015 - 08:02 PM
Guess I better take the dash out and change the master cylinders.
Dash out to get to the MC's??
MC's themselves are normally in the same location as the standard one, eg. under the service hatch in the nose.
The dash top in the S1 is normally an intergral part of the windscreen surround and non-removable. Only the leading edge panels can be removed.
The rest of the work is normally done in the footwell area if you need to disconnect pushrods from the pedal or balance bar (if fitted)
#348
Posted 23 August 2015 - 07:57 AM
Should be all inside the footwell area where (if you lie on your back on the floor) you can access the top of the pedals. Quite cramped but that should be where it's all located.
Dash is well above and shifted towards the inside of the car from that and should have nothing do do with it unless someone did a major bodge-job in fitting this (non-standard and steel from the looks of it) pedalbox to the car and cut a lot more than needed..
Eg. it doesn't look like a Pilbeam setup: http://www.pilbeamra...ct_2/index.html
Standard full-ali pedal box would be like this:
Normally the S1 Elise/Exige runs a single twin-chamber master cylinder like this:
Your setup with a dual MC and balance bar is very much aftermarket..
#350
Posted 23 August 2015 - 08:13 AM
And here lies you problems.......
#351
Posted 23 August 2015 - 08:28 AM
#352
Posted 23 August 2015 - 12:06 PM
#353
Posted 23 August 2015 - 12:08 PM
#354
Posted 04 September 2015 - 12:23 PM
Brakes are fixed oh and bought myself some of these:
304mm super light bells and rotors
Along with a new spoiler... But that will be going back as it doesn't fit my mounts (yes I did confirm sizes on the phone but there was a communication error!)
So I am thinking about swapping it for the motorsport straight spoiler I used to have on the Vx
Anyways I have had confirmation from pilbeam and I think I will swap the pedal box over to there product either at Xmas or if the master cylinders goes again before then
Edited by The Batman, 04 September 2015 - 12:25 PM.
#356
Posted 15 September 2015 - 07:07 AM
#357
Posted 15 September 2015 - 09:36 AM
#358
Posted 18 September 2015 - 12:40 PM
Finally you have realised.I'm wrong
#359
Posted 23 September 2015 - 04:04 PM
another wheel bearing is dead
bloody stupid car... you know its bad as when you do as many miles in a french shed and that doesnt break down at all...
good thing i gave it a good check before the national though.. getting checking dudes and dudettes!!
i am off to eliseparts tomorrow morning to get the part
#360
Posted 23 September 2015 - 07:48 PM
Edited by haggi961, 23 September 2015 - 07:48 PM.
