could you get that in a vx and run it with a stand alone ecu..???
I think the amount of challanges could be comparable to the sweed putting in a V10 in his S2.
Posted 23 December 2015 - 12:21 AM
Posted 25 December 2015 - 03:36 PM
Posted 25 December 2015 - 06:08 PM
Edited by The Batman, 25 December 2015 - 06:09 PM.
Posted 01 January 2016 - 09:59 PM
Edited by The Batman, 01 January 2016 - 09:59 PM.
Posted 01 January 2016 - 10:07 PM
Posted 01 January 2016 - 10:11 PM
Posted 03 January 2016 - 03:30 PM
right so work has begun.. vocky popped over so we cracked on
first step was to remove subframe as the engine cannot be removed without it.. to be honest the intake manifold cant even be removed without taking the engine out unless you get rid of the stupid studs.
i am reusing the block so the old engine needs to be stripped
then it was time to remove that god awful silver crap and cut a bulkhead as the new manifold etc wont fit as the old standard manifold hits thee bulkhead, luckily i still have my vx bulkhead so i will reshape and fit that (4th vx part that will be on the loti if anyone is counting
luckily all of this is happening to be honest the previous owner was a bit weird.. all the bolts where either extremely tight and i mean tight!! or they where just nipped. or the odd bolt missing
the clutch was dead
oil filter was hand tight
belt tensioner bearing is dead
it has stainless steel exhaust bolts (great!!!) but standard rusty bolts that arent so great
anyways, off to walk the dog and then settle down for the evening with a hot air gun and a scraper to get that silver foil/foam off the chassis/bulkhead YAY!!
Edited by The Batman, 03 January 2016 - 03:30 PM.
Posted 03 January 2016 - 03:44 PM
this isn't going to be a lotus parts sale soon i hope ;-)
Posted 03 January 2016 - 03:53 PM
Posted 03 January 2016 - 05:07 PM
Did you check oilpan underpanel distance? Any left over parts for me? I can take your old head
Br,Per
Posted 03 January 2016 - 05:32 PM
Posted 04 January 2016 - 08:23 AM
please note the before and after (Joe cut his head) pictures of the lotus, especially the ends of the sills / wheel arches
ps: I have a strong dislike for Honda engines
pps: how heavy is a Honda gearbox
ppps: you need the Honda just to move the extra weight of the gearbox
Posted 04 January 2016 - 11:41 AM
How and why do you have a dislik for the supreme Honda Engines?
Br, Per
Posted 04 January 2016 - 11:48 AM
Posted 04 January 2016 - 12:36 PM
Wow, this is a big project, best of luck. At least it is raining non stop in the UK so you don't feel bad that it's off the road
Posted 04 January 2016 - 06:10 PM
Posted 07 January 2016 - 02:48 PM
the postie arrived!!
decided to replace all the wishbone bolts with a new set, also a pair of stainless steel exhaust hanger brackets. oh and some rear caliper bolts
going to replace the heat shield on the exhaust with titanium stuff, will also do both the u bends
new gearbox oil, fuel filter and fuel pipe clips
new rear brake lines, hoses (current are blue!) thermo insulation for cables etc, nimbus for driveshaft boot and toe links heat shield, new tensioner pulley and idler pulley as the current ones sound like the bearings are gone or pretty much gone!
Posted 07 January 2016 - 06:15 PM
