The Darkside Project
#561
Posted 13 January 2016 - 07:15 PM
#562
Posted 13 January 2016 - 07:22 PM
#563
Posted 13 January 2016 - 07:54 PM
The standard bottom end of a k20 can handle 400bhp!Floating liners just like the z22. Wonder how stable they are?
#564
Posted 13 January 2016 - 08:22 PM
Edited by Aerodynamic, 13 January 2016 - 08:24 PM.
#565
Posted 13 January 2016 - 10:51 PM
#566
Posted 13 January 2016 - 11:04 PM
......starts to worry ..............
#567
Posted 13 January 2016 - 11:06 PM
fcuk it get the dremel out !!!!!
#568
Posted 14 January 2016 - 07:42 AM
Not floating. They are iron/steel liners that the block is basically cast around. They are ridged on the outside and permanentlly fixed in the block.
To exchange the liners/cylinders for bigger ones (eg. Darton sleeves) you need to do stuff like this to the block:
And then press new liners into the base of the block for really big bores or a closed-deck construction for increased upper cylinder strenghth with very high boost applications.
Edited by Arno, 14 January 2016 - 07:44 AM.
#570
Posted 14 January 2016 - 06:39 PM
Do these blocks break in half with all that material removed? Heard of a few darton Lsj blocks failing this way.Not floating. They are iron/steel liners that the block is basically cast around. They are ridged on the outside and permanentlly fixed in the block. To exchange the liners/cylinders for bigger ones (eg. Darton sleeves) you need to do stuff like this to the block: And then press new liners into the base of the block for really big bores or a closed-deck construction for increased upper cylinder strenghth with very high boost applications. Bye, Arno.Floating liners just like the z22. Wonder how stable they are?
#572
Posted 14 January 2016 - 08:06 PM
And not to mention the lesser cylinder cooling the Darton blocks seem to have. According ZZP they run hotter and are more phrone to knock... (Not really a problem on the drag strip, more so when you track it... )
#574
Posted 15 January 2016 - 04:54 PM
Never heard of that issue with the Honda K20/K24 blocks that got this treatment (other stuff though like coolant leaks and bad headgasket seals.. yes...). I guess the wall thickness of the block itself and at the bottom is still sufficient to keep it in check.
Some of the girdles used to make closed decks are pressed and welded into the block too although that does carry the risk of the block warping too much to ever work again.
Converting from open to closed deck blocks usually need a careful tradeoff between strength and cooling as indeed the flow to the cylinder head can become compromised if the openings get too small while you do get more upper cylinder strength to resist high pressures. Balancing act...
But as with much US based stuff it's important to remember that many, many of their high power/boost/nitrous builds (irrespective of brand/engine/type) are built for drag-race or similar use, so these engines see max power only about 10 seconds at a time and are called 'reliable' if they do 50 or so 'pulls' before needing work.
We, on this side of the pond, have this funny idea of wanting to drive cars fast in circles on tracks for loooooong times and a number of bits that work great on a drag engine are ummm.. not that great on a track car
#576
Posted 26 January 2016 - 07:10 PM
Fixed a water leak aswell and blanked off the pipe work that runs coolant through the intake manifold.
Had a nice painted cam cover until greasy mits kept touching it :lol. Will give it a light paint again still better than the gay red though!
#577
Posted 27 January 2016 - 01:02 PM
#578
Posted 27 January 2016 - 01:57 PM
#580
Posted 02 February 2016 - 08:36 PM
Bing (1)
