The Darkside Project
2139 replies to this topic
#581 The Batman
Posted 02 February 2016 - 09:07 PM
Those are photos of the standard intake manifold. Have blanked it all off so my intake or tb hasn't got coolant running through it! Hopefully have engine in this week :blink:
#582 Arno
Arno
  • 1,238 posts
Posted 03 February 2016 - 12:05 PM
Here is a couple of photos of the intake manifold
Those are not coolant ports.
The throttlebody is heated on the Civic to stop it freezing up in cold climates. That's an actual coolant feed and usually deleted.
The ports you show on the manifold however serve different purposes:
  • PCV vacuum port => PCV valve is screwed into the block/waterpump housing and oil vapour is sucked from the block through this and air is drawn into the engine via the valve cover connection
  • Cold-start assist and idle elevation => secondary air feed into the intake ports controlled by a thermostatic element screwed into the coolant pipe that closes off the air feed once the coolant is up to temperature
The cold start air feed uses channels moulded into the manifold and the small holes above the intake ports you can see in the manifold flange to allow additional air to bypass the TB during engine warm up.
Both are not needed although you may need to fit a catchtank on the valvecover connection if you block off the PCV ports on the block and manifold as it will now 'exhale' out that port and bring more vaopur and droplets out.
#583 The Batman
Posted 03 February 2016 - 07:21 PM
apologies my mistake! they looked like they where going into the water pump etc!
anyways, not a big update i must admit but i have cleaned and fitted new pullies to these bad boys
then a boring photo of changing the hoses from fast and furious blue to black and chassis piece below the bulkhead, this is a known fault on the s1, water seats in it and corrodes the chassis, i have sanded back the corrosion and then painted
still progress is progress eh?
hopefully have a bigger update this weekend
chinky chinky
#584 Arno
Arno
  • 1,238 posts
Posted 04 February 2016 - 09:02 AM
Now is the time to fit a nice big Laminova C43-332 in the hose that runs along the bottom rail and ditch the awful Honda 'donut' cooler under the oil filter. A takeoff and some nice braided PTFE oil hoses and you're set.
Second action would be to additionally install a dedicated takeoff on the block and move the oil filter to a bracket on the back-stay for easier access and filter changes.
Not trying to induce 'feature creep'.. Really! :D
#585 The Batman
Posted 04 February 2016 - 10:54 AM
Is there a 'kit' available?
#586 Arno
Arno
  • 1,238 posts
Posted 04 February 2016 - 12:03 PM
Kinda...
Second option here: http://www.hondaelis...nal-extras.html
Although AFAIK they only sell parts to existing LinkUp converted cars..
Remote oil filter is something most people do by themselves.
#587 The Batman
Posted 04 February 2016 - 08:01 PM
hmm will have a think about it but probably wont tbh unless i find i have a problem!
here is an update
mocked up the inlet filter and pipe
p.s. i prefer vxs.
Edited by The Batman, 04 February 2016 - 08:02 PM.
#588 CHILL Gone DUTCH
Posted 04 February 2016 - 08:12 PM
vauxhall header tank
  :tt:
#589 The Batman
Posted 04 February 2016 - 08:33 PM
Oh yes, there seems to be a few Vx parts going back on rallly
#590 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 04 February 2016 - 09:14 PM
Chop chop old boy
#591 The Batman
Posted 04 February 2016 - 09:16 PM
You blown your engine yet?
#592 D-DAWG83
D-DAWG83
  • 1,276 posts
Posted 04 February 2016 - 10:28 PM
Looks good. Am i right in thinking that it has no rocker cover by the looks of it, and its just the head and the block?
#593 The Batman
Posted 04 February 2016 - 10:32 PM
na the cover is just stupidly huge! for all the vtec goodness underneath
#594 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 04 February 2016 - 10:36 PM
Will yours be ready before G's? :lol:
#595 The Batman
Posted 04 February 2016 - 10:38 PM
yeah! unless i have missed something,
im hoping to get it ready for march, then need to get it booked in for a remap and geo
#596 D-DAWG83
D-DAWG83
  • 1,276 posts
Posted 04 February 2016 - 10:43 PM
Ah ok, thought it was a little odd. Great progress, puts mine to shame
#597 The Batman
Posted 04 February 2016 - 10:52 PM
You can pop round Saturday if you want, going to clean the subframe and paint it :lol:
#598 D-DAWG83
D-DAWG83
  • 1,276 posts
Posted 04 February 2016 - 10:56 PM
With some more brake cleaner yeah? I maybe about Saturday, work dependant if so, il see if i can take the Zed out on a trip, and come over. With brake cleaner
#599 The Batman
Posted 04 February 2016 - 11:02 PM
I think it's going to need acid :lol: Speaking of 350, a guy round the corner just sold his and bought s Range Rover, one extreme to the other!
#600 andyrob
andyrob
  • 120 posts
Posted 04 February 2016 - 11:09 PM
Looks like you're making good progress, hope to see some good results from the remap
12 user(s) are reading this topic
0 members, 12 guests, 0 anonymous users
