The Darkside Project
#781
Posted 15 June 2016 - 09:05 AM
#782
Posted 24 June 2016 - 11:08 PM
engine is now ready for collection
ended up having new cams fitted as the ones that where fitted didnt suit the high comp pistons and at 30degrees only allowed 1mm piston/valve clearance which at 9000revs would have a high risk of kissing!
so got new cams fitted supplied and installed by CPL Racing.
Also had a hard stop fitted at 40degrees so that there is no chance of it exceeding the limit.
hoping to pick it up monday ready to install it monday / tuesday / wednesday (aslong as my bimmer is fixed by then!!) then drop it back down there so they can map it... so wish they where in aylesbury
Edited by The Batman, 24 June 2016 - 11:09 PM.
#783
Posted 25 June 2016 - 07:10 AM
Good luck, am keen to see (and hear) this thing in action.
#784
Posted 27 June 2016 - 04:34 PM
Vtec set to 40degrees with a hard stop.
Plan is to hopefully get it in the car tomorrow.
Guy at CPL Racing told me to bin the cat off the car so I decided to get Vocky to weld a small silencer in there instead (every little helps right?!)
#785
Posted 27 June 2016 - 05:49 PM
That things screams it´s lungs out at 9k rpm, and you decide to remove that last little piece of sound killer.
Brave man.
You may have to spend your Zandvoort day at the beach. (With Coco if i´m not mistaking)
#786
Posted 27 June 2016 - 06:18 PM
Coco JG And petervxr Basically all the lotus carsThat things screams it´s lungs out at 9k rpm, and you decide to remove that last little piece of sound killer. Brave man. You may have to spend your Zandvoort day at the beach. (With Coco if i´m not mistaking)
Edited by CHILL Gone DUTCH, 27 June 2016 - 06:19 PM.
#787
Posted 27 June 2016 - 06:19 PM
#788
Posted 27 June 2016 - 06:30 PM
#789
Posted 27 June 2016 - 06:59 PM
Lol I will be fine!
It'll just be everyone else with tinnitus!
#790
Posted 27 June 2016 - 07:13 PM
#791
Posted 27 June 2016 - 07:19 PM
Just lift a little at corner exit when you get on the straight.
That´s where the meter is.
#792
Posted 27 June 2016 - 07:22 PM
#793
Posted 27 June 2016 - 07:25 PM
At least the brakes are fine now.
#794
Posted 27 June 2016 - 07:27 PM
#795
Posted 27 June 2016 - 07:28 PM
#796
Posted 27 June 2016 - 07:30 PM
Come to think, this whole rebuild starting with some braking problems at Zandvoort 2015.
1 year later, and 0 miles done, it´s being prepped for Zandvoort 2016.
Amazing.
#797
Posted 27 June 2016 - 07:31 PM
#798
Posted 27 June 2016 - 07:33 PM
#799
Posted 27 June 2016 - 07:35 PM
#800
Posted 27 June 2016 - 07:38 PM
Living the dream.....!!
Is that what you've been reduced to after all this engine rebuilding....eating pink pigs?
