quick google says i think they had a problem with the vtec solenoid.
ive removed it and cleaned it along with testing to make sure it opens
Posted 15 September 2016 - 08:38 PM
Posted 15 September 2016 - 09:36 PM
Oil pressure filter sealant. @1min 30.
http://www.dailymoti...-segment-2_auto
Edited by smiley, 15 September 2016 - 09:38 PM.
Posted 15 September 2016 - 09:46 PM
Posted 16 September 2016 - 06:39 AM
If you have a EU K20A2 engine and the VTEC oil pressure switch is working (and enabled in the ECU), and you can (perhaps with some power loss) still rev to >7500rpm then VTEC is working OK.
On a K20A2 if the VTEC does not activate the ECU can/will detect this via the VTEC oil pressure switch (set at 1 bar AFAIK) and limit the rpm's to around 5500rpm and it won't go higher. It's meant as an oil starvation protection. JDM K20A's and ECU's don't have the VTEC pressure switch, so will happily (try) to go into VTEC even with (too) low oil pressures.
Do you have a K-pro or similar in your ECU? A datalog should quickly show up any oddities in sensor readings..
Posted 16 September 2016 - 08:26 AM
Posted 16 September 2016 - 02:26 PM
Since you'll be getting bored of it being NA by now;
Dropped into a Honda tuners near me to pick up a fuel pump and they showed me their Rotrex kit for a K20Z, looked like a great installation.
This one, actually
Posted 16 September 2016 - 06:27 PM
Posted 16 September 2016 - 06:29 PM
Posted 17 September 2016 - 01:26 PM
You would not have been on your own today at Hethel ,A S1 Exige with a Honda conversion kept breaking down
Posted 17 September 2016 - 03:17 PM
Useless cars with useless engines.
Posted 17 September 2016 - 03:52 PM
Edited by The Batman, 17 September 2016 - 03:54 PM.
Posted 17 September 2016 - 06:08 PM
Posted 17 September 2016 - 07:36 PM
there is a couple of these, mr beef wants in on the action
Posted 17 September 2016 - 07:51 PM
Yeah but he's like a professional driver!
And he could shoot us too!Yeah but he's like a professional driver!
Posted 17 September 2016 - 07:54 PM
hes an army boy so probably shout you with his 'water' pistol
Posted 17 September 2016 - 07:58 PM
I would still be frightened😨 (I thought he was RM)hes an army boy so probably shout you with his 'water' pistol
Posted 17 September 2016 - 08:00 PM
hes not Roger Moore
Posted 18 September 2016 - 07:54 AM
Navyhes an army boy so probably shout you with his 'water' pistol
