I was right!Navyhes an army boy so probably shout you with his 'water' pistol
The Darkside Project
#1081
Posted 18 September 2016 - 08:37 AM
#1082
Posted 18 September 2016 - 11:41 AM
#1083
Posted 18 September 2016 - 11:47 AM
#1084
Posted 18 September 2016 - 03:59 PM
#1086
Posted 18 September 2016 - 08:00 PM
one plus side is i seem to have fixed my laptop
#1087
Posted 18 September 2016 - 08:03 PM
#1088
Posted 18 September 2016 - 08:04 PM
had a nightmare at pc world... bunch of useless twats..
anyway, laptop is alive now which is good. so live datalogging tomorrow until i mess something else up
first step is to recalibrate the TPS
#1089
Posted 18 September 2016 - 08:12 PM
Gaffer can help you with that!first step is to recalibrate the TPS
#1090
Posted 18 September 2016 - 08:15 PM
would adjusting the cable adjust the this setting?
#1091
Posted 18 September 2016 - 08:39 PM
Mark will help you with all your issues, good job you've not been taking the p*ss. Brave brave men......
#1092
Posted 18 September 2016 - 09:27 PM
Off the forum for 2 days and look what happens, everyone gets brave
#1093
Posted 18 September 2016 - 09:28 PM
Edited by The Batman, 18 September 2016 - 09:29 PM.
#1094
Posted 19 September 2016 - 06:26 AM
Is that screenshot at idle? Looks a little off...
Idle seems high. Normally Honda's are set to between 750-850rpm for idle. What's the target setting under the 'idle' tab (if you have the .KAL file it was mapped with?)
Also it's not runing closed-loop? (fuel status: Open - Driving) By design in the map/.KAL or something wonky with the lambda sensor causing it to not go into closed-loop running?
#1095
Posted 19 September 2016 - 12:05 PM
#1096
Posted 19 September 2016 - 02:48 PM
Ok for some reason i dont think its going into closed loop
when i floor it my afr.cmd goes to around 12.6 but afr;1 stays at 14.7
when the vtec stops working the throttle pedal gets harder.. randomly
knock ignition limit is at 40'
my coolant guage on the stack dash seems to be registering about 3 degrees lower than the ecu is reading it.
unfortunately as i dont have the map i cant set the tps
so.. as all i have done is confuse myself, im going to fit a new fuel tank and pump along with a new throttle cable lol least that gets some jobs of the list for winter.
Edited by The Batman, 19 September 2016 - 02:50 PM.
#1097
Posted 19 September 2016 - 04:40 PM
What's the "AFR:1" displaying (you have an explanation/help file?) Is that not simply a (stochiometric value) setting for petrol?
AFR.CMD is the commanded ratio the ecu wants to see. Does this have a WB fitted, or do you see the fuel trims/narrow band switching in closed loop?
#1098
Posted 19 September 2016 - 05:04 PM
AFR - The air/fuel ratio is calculated from the stock lambda sensor. Note that JDM, USA and some other vehicles have a semi-wide band sensor, with a range of approx 11.5:1 to 30:1 European spec vehicles utilize a narrow band sensor, with a range of 14.5 - 14.9:1.
AFR.CMD - The air/fuel ratio command is the target air/fuel ratio as determined by the ECU. Note: The A/F CMD is ignored when the ECU is operating in open loop.
I dont think it has a wideband fitted.
#1099
Posted 19 September 2016 - 05:19 PM
Hmmmm.. So the question is if your narrow band sensor is working correctly.
You normally can see/log the switching voltage in closed loop running/idling, together with the changing values of the short term fuel trims...
#1100
Posted 19 September 2016 - 06:04 PM
hmm worth replacing to rule out i guess!
