The Darkside Project
2139 replies to this topic
#1261 The Batman
Posted 16 December 2016 - 04:21 PM
I have a crowbar :lol:
#1262 The Batman
Posted 17 December 2016 - 10:47 PM
well.... looks like the 2bular wont fit with mine or a few other engine mounts...
so looks like a bespoke one will have to be made.. the downside to having everything 'aftermarket'
hmmm
#1263 The Batman
Posted 08 February 2017 - 10:40 AM
On a different note... Went to back on track yesterday and had new cv boots finally fitted! They have been going for a long time so decided better get it sorted and as I knew that jezza loves to get greasy decided to give the job to him :lol: :lol: Also fitted a motorsport roof scoop that I'm not 100% sure it was the right move or not but will run it and see if it grows on me :) Big thanks to back on track!
Edited by The Batman, 08 February 2017 - 10:41 AM.
#1264 Nev
Posted 08 February 2017 - 10:52 AM
hmmm
Have you considered buying a TIG welder and making your own? It's quite cathartic and much the same price in the end, but you are left with a TIG welder that will serve you well for many other jobs...
Edited by Nev, 08 February 2017 - 10:52 AM.
#1265 The Batman
Posted 08 February 2017 - 11:03 AM
Na I know my abilities and would rather pay a specialist I have a price of £900 for basically a copy of hpe exhaust custom made and fitted manifold 4-2-1 and into my original 2.5" 2bular backbox. So at that price I see no point in attempting especially after how much Vocky's exhaust cost and how much your backboxs are costing
#1266 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 08 February 2017 - 10:57 PM
Let's see some pics of the MS roof.... No photoshopping either you freak!
#1267 The Batman
Posted 08 February 2017 - 11:15 PM
it still needs some fettling, hoping to have time to do it on friday.. the eliseparts fiberglass quality is pretty shite, either that or they have abused the mould to the point of destruction :lol:
#1268 The Batman
Posted 12 February 2017 - 09:49 PM
Motorsport roof scoop fitted :)
Not the best photos but only just finished it and loaded trailer ready for brands tomorrow rallly
#1269 The Batman
Posted 15 February 2017 - 11:29 PM
well to update this, the trackday at brands went very well and really enjoyed it after the fwd boys dried the track out :lol:
the car performed excellent and the old gay really does still go well, but then it is kinda like triggers broom :lol:
problems on the day:
same crap with the throttle body at start of the day sticking a little bit which wd40 sorted, im assuming its a problem with the cold weather (too tight to spend 1k on a toda throttle body, perhaps i should start a just giving page ;) )
other problem is the one that i have had last couple of trackdays but seems to be getting worse.. is a groan coming from (suspected) rear pax caliper which im hoping is a easy fix
only one black flag but that was going down pit straight with mitm and strugs :lol:
So thats the plan for next week:
- check out the calipers, but annoyingly i cant get enough heat into the brakes to cause the groan on the road so cant confirm until next trackday.
- Oil and filter change
- also need to fit a shift light :lol: :lol: i dont think my neighbours would be pleased if i started revving to 9k to set it up though so better go to industrial estate at weekend :)
#1270 gaffer1986
gaffer1986
  • 4,408 posts
Posted 16 February 2017 - 06:52 AM
Down blame you for not wanting to spend £1000 on a single throttle body. Is there a cheaper option?
#1271 fezzasus
Posted 16 February 2017 - 09:08 AM
Surely the cheaper option is to find a better grease. WD40 doesn't last long, especially when in the relatively high vacuum of a throttle body.
#1272 The Batman
Posted 16 February 2017 - 12:33 PM
Yeah it lasted a long time when I sprayed the spring with white grease but didn't have any on me :)
#1273 The Batman
Posted 24 February 2017 - 06:29 PM
Well decided to look at making some rear brake cooling ducts
So bought some naca ducts then cut and bolted carbon fibre to the top and fiberglassed some 32mm tube to it
Then tried to find best place to fit them and decided on mounting on the undertray like this:
Mounted duct using 3 bolts 2 on one side and 1 through the whole thing with a aluminium insert in the duct
Here's one form underneath:
Now I've decided I'm going to change the front cooling pipes for larger ones so will get some bits ordered :)
#1274 gaffer1986
gaffer1986
  • 4,408 posts
Posted 24 February 2017 - 07:25 PM
Very good handy work there!
#1275 The Batman
Posted 24 February 2017 - 07:31 PM
Thank you
#1276 The Batman
Posted 11 March 2017 - 07:58 PM
Well cracked on with the car today, started off by fitting my new brake cooling ducts into the mesh either side of the grill. Put some tights on them to stop crap going through! Will update for this tokorrow as I forgot to take one :beat:
But here are the ducts, then fitted 51mm hose
Then me and mark decided to debadge it :o
Also forced to fit new indicator stalks
Then went to fit the shift light but accidentally applied too much pressure to the glass lense on the speedo (yes it's glass on a s1!) so cracked it so removed it and stuck back
As good as new :lol:
Was going to buy some Perspex and make a new one using that as a rough template but luckily I'm in the clique and there is one 20mins away at casa del vockys!
So then decided to remove the carbon binacle cover as it has faded over time and gone a bit greeny so delegated that job to mark and he did good!
So now I have a carbon fibre space helmet!
And Jesus that binacle cover (not space helmet) is heavy! Madness.
#1277 The Batman
Posted 11 March 2017 - 08:03 PM
The main event was use some dibond that I've had in the garage for approx 1 and a half years :lol: and make some side skirts!
Before
After
#1278 The Batman
Posted 11 March 2017 - 08:05 PM
Other side
Just need to buy some edge stripping to put along the sharp edge will do the splitter whilst I'm there aswell.
#1279 SteveA
SteveA
  • 9,156 posts
Posted 11 March 2017 - 08:36 PM
Car looks lovely, can you please move the awful Lotus out of the way so we can get a better look :lol:
#1280 The Batman
Posted 11 March 2017 - 08:38 PM
You can be so mean should be nice to the old gal she's 20 in November
