The Darkside Project
2139 replies to this topic
#1481 The Batman
Posted 11 December 2017 - 08:08 PM
cracked on again with test fitting the backbox now the manifold fits
As you can see the U bend isnt long enough but it does line up with my backbox (as i was being a tight ars and not buying the correct backbox for the system!! as mine is perfectly fine for track) So going to fit a small flexi in there along with a v band to finish it all off :)
now to strip it all down again and actually finish removing the gearbox which means subframe off grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr :9mm: but whilst the subframe is off im going to fit a new modified wiring loom which i had spare
Edited by The Batman, 11 December 2017 - 08:09 PM.
#1482 Arno
Arno
  • 1,238 posts
Posted 12 December 2017 - 09:26 AM
Curious as to why? Honda engine + GB (without the intake and exhaust manifolds) can be lifted as a complete unit out of the car without messing with the subframe.
Use a balance bar on an engine hoist and then lift it up so the engine is angled upward on the pulley end, gearbox down and then slightly pivot it to turn the diff housing from under the subframe edge and done. Put some foam padding on the lower wishbone cross-bar to stop the gearbox casing banging onto that one.
Unless you don't want to lift but want to roll the engine+GB out of the car on a dolly or similar.. Then you indeed do need to take the subframe off.
#1483 Nev
Posted 13 December 2017 - 04:50 PM
Crikey so much fiddling about just to get a couple of extra HP, is actually worth it?
#1484 The Batman
Posted 13 December 2017 - 06:16 PM
Probably not but you must like tinkering with your car to try and get everything out of it?
#1485 Nev
Posted 13 December 2017 - 07:00 PM
Not any more really, I think I've fully itched the car bug now. When I embark on anything I usually weigh up the gains vs the costs (time + money), I guess that's why I went the whole hog with my project, as going to all the effort and only adding a handful of HP wasn't going to be worthwhile for me.
Nowadays I just like driving it and hoping it stays reliable. :unsure:
I think I'm finally getting too old for fiddling with cars, boats, stereos etc etc.
Edited by Nev, 13 December 2017 - 07:22 PM.
#1486 The Batman
Posted 13 December 2017 - 07:32 PM
Problem is with me a few Hp is a good achievement being Na still where as with a turbo its poihtless Sounds like youre getting bored!
#1487 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 13 December 2017 - 07:34 PM
Close protection is where its at now Nev :D
#1488 Nev
Posted 13 December 2017 - 07:36 PM
Once you've got your S/Cer on you'll be in the same boat no doubt. :)
On my setup I gain about 30 HP per Lb of boost, I expect you'll be quite close to that, somewhere around 20 to 25 HP maybe? Once you've got that on tap, you'll be laughing (or crying once you realise the wheels/tyres + brakes + other things on the car are inadequate!).
I still haven't even got round to collecting and fitting those new front wheels + tyres for Nipper yet. :(
Edited by Nev, 13 December 2017 - 07:39 PM.
#1489 vocky
Posted 14 December 2017 - 08:44 AM
getting more power from a turbo engine is so simple, it's just a lazy way of doing things :lol:
getting more power from a NA engine is a challenge, but much more rewarding rallly
#1490 Nev
Posted 14 December 2017 - 09:31 AM
Somebody sounds bitter! :P
#1491 vocky
Posted 14 December 2017 - 11:23 AM
I also have turbo (A20NFT), a quick remap, induction and precat delete gave it 340bhp
Quite a boring tuning route :P
#1492 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 14 December 2017 - 11:31 AM
What have you got that in Vocky?
#1493 vocky
Posted 14 December 2017 - 12:07 PM
Astra J VXR :)
#1494 The Batman
Posted 14 December 2017 - 01:24 PM
Chav
#1495 SteveA
SteveA
  • 9,156 posts
Posted 14 December 2017 - 01:29 PM
Chav
Says VTEC boi there :lol:
#1496 The Batman
Posted 14 December 2017 - 01:46 PM
Dont forget its asbo orange :lol:
#1497 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 18 December 2017 - 07:44 PM
PInk.
#1498 The Batman
Posted 18 December 2017 - 07:53 PM
proper orange compared to these lotus orange colour :P
#1499 The Batman
Posted 20 January 2018 - 03:25 AM
well its been a crap 1 month (loti wise!) not much has been done on it all
but i did manage to grab some DEI titanium wrap of Graeme that he was selling so i decided to wrap the exhaust tonight:
unfortunately it wasnt enough :lol: :lol:
so i have ordered some more, which is wierd but the cheapest place i found to buy it was euro car parts?!
I also dropped my U bend and flexi parts off to Vocky who is going to cut the V band of the U bend and weld it to the flexi joint and weld that to the U bend completing the exhaust system (fingers crossed!) Also welding in a extra lambda bung for wideband when mapping.
Hopefully there will be another update soon with a gearbox out of the car!
#1500 pete-r
pete-r
  • 2,771 posts
Posted 20 January 2018 - 09:29 AM
Looks good, hope you soaked it in water first or wore a mask if you did it indoors.
