The Darkside Project
#1961
Posted 20 December 2018 - 01:40 PM
#1962
Posted 20 December 2018 - 02:28 PM
#1963
Posted 20 December 2018 - 03:37 PM
#1964
Posted 20 December 2018 - 06:00 PM
my system doesnt use a thermostat. The pump controls the temperature by start/stopping
Anyways managed to get a bit of time on the car today... Mainly wanted to check this dreaded sill coolant hose that runs down the chassis. So blocked one end, and fitted a compressor to the other end, ran it up to 2 bar and you could hear it escaping in the front
so this confirms this is the damaged pipe causing the leak which is a real pain in the ars. there is a rivet that rubs on the coolant pipe on pre '99 cars.
Going to remove it and either repair or replace... either way it really isnt a fun job that i can only imagine a lot of swearing is going to come from it!!
bad times
#1965
Posted 21 December 2018 - 06:26 PM
bingo
not sure how i got part A out of Part B
photograph credit goes to zoobeef.
#1966
Posted 29 December 2018 - 06:56 PM
right.... so my fuel system has arrived!
Then decided on running a hose down the chassis instead of the pipe, mainly as this means the same problem wont happen again!
this is the other end (after it fell out of fld's mum)
#1967
Posted 29 December 2018 - 07:55 PM
Are you putting a soup charger on this at any point Joe? 350whp should be enough to deal with all these new V6's
#1968
Posted 29 December 2018 - 07:57 PM
pfffttt i only needed 250 to beat all the v6's just ask petervxr
why do you think he has spent so much on it, hes just trying to beat me!!
#1969
Posted 29 December 2018 - 08:16 PM
bingo
Are you putting that Flymo on the underside of your car? That way when you spend all that time on the grass at the tracks you could cut it too, and maybe get a discount on your track day?
#1970
Posted 29 December 2018 - 08:20 PM
thats why i bolted side skirts and front splitter and lowered rear diffuser, can cut the grass as i go then
#1971
Posted 30 December 2018 - 12:14 PM
Lol - nice one...
#1972
Posted 30 December 2018 - 06:42 PM
only had a spare 5 mins today so decided to brace the side of the splitter
bit of heat shrink to tidy them up
hopefully the new rad hoses will come this week, then i can cut them and mount the electric pump, as i have a spare it will make life easier having it mounted at the front behind pax arch liner as this means i can change it at the track if it dies. Also moves a bit of weight to the front which is always good!
#1973
Posted 30 December 2018 - 06:56 PM
Whats your reasoning for fitting an electric pump when the mechanical one works well?
#1974
Posted 30 December 2018 - 07:00 PM
i like to breakdown
na to be honest, i want to free up as many hp as possible, help it rev faster, less weight as the k20 pump is rather heavy! plus this allows me to carry on pumping coolant round with the engine off
and its something shiny to fit
#1975
Posted 30 December 2018 - 07:35 PM
Having it run after switch off is handy especially if you stall it on track & it wont re start.
Are you removing the complete water pump housing & replacing with a plate? If not I'd be supprised if there is any weight saving.
Not sure how it frees up any extra power though, cant work that one out........
#1976
Posted 30 December 2018 - 07:45 PM
yup complete pump assembly removed and flat plate fitted to seal it.
no parasytic loss, there is alot of claims of 5-10bhp on the k20 engine. id be more than happy with just 5
#1977
Posted 30 December 2018 - 08:12 PM
How does that work? I cant see how it can be any better, if anything it has to be worse when the engines on full power...…..
#1978
Posted 30 December 2018 - 08:19 PM
why would it be worse
#1979
Posted 30 December 2018 - 08:35 PM
#1980
https://auto.howstuf...efit-engine.htm
another main positive is it can stay at constant full power for when coolant temps start to creap up
