Still Not Starting Right, Cry For Help!
Posted 22 February 2015 - 11:19 AM
Posted 22 February 2015 - 11:29 AM
could it be a duff / faulty fuel pump ?
might be worth sticking a fuel pressure gauge on
Posted 22 February 2015 - 11:37 AM
Posted 22 February 2015 - 11:40 AM
Posted 22 February 2015 - 11:53 AM
Posted 22 February 2015 - 11:59 AM
Posted 22 February 2015 - 12:02 PM
Edited by CHILL Gone DUTCH, 22 February 2015 - 12:03 PM.
Posted 22 February 2015 - 12:12 PM
Posted 22 February 2015 - 01:27 PM
Posted 22 February 2015 - 01:39 PM
It was Pete-r I was a thinking of that had cold start problems that was cured with a fuel pump relay. Didn't realise yours was cured with a different map Bargi, were you having similar cold start problems?The relay problem I had was with the charge cooler. In the end Peter sent me 3 different maps with different advance settings and one of them endes up working really well. Still not as good as the CS map at starting but miles better than it was. Send him your current map and ask him to do his magic.
Posted 22 February 2015 - 04:01 PM
Posted 22 February 2015 - 05:22 PM
Def drops instantly with Walbro on mine. By again no probs when on CS map.Though I think there's some debate over what's normal for the Walbro? Some say it drops the pressure the instant it stops priming and some say it holds it?
So when you went to Dutch ECU? As I mentioned ping Peter. The only other thing I needed to do after I swapped was drop the plug gap to .75mm to solve stuttering under load. It shouldn't affect starting but hey its £6 from Halfords for the tool and who knows.It definately started when it was supercharged
Posted 22 February 2015 - 05:25 PM
Posted 22 February 2015 - 06:05 PM
Edited by Nev, 22 February 2015 - 06:21 PM.
Posted 22 February 2015 - 06:26 PM
I thought I'd looked there, last one I found from you was about using a different throttle body and checking the fuel pressure? Unless I missed one?yeah check out my post about the weird cranking error. Pretty sure you were the first one to post in it
Ok, so when I test as long as it hits 3.8psi while priming, cranking and running then all is ok there? Even if it drops back to nothing instantly.Def drops instantly with Walbro on mine. By again no probs when on CS map.
I've already spoken to Peter and he sent me 3 adjusted maps, didn't seem to make a difference but I didn't test thoroughly as by this point I'd found the vacuum leak and (stupidly) thought all faults were caused by the same problem. Will ping him again as I'll need him to adjust my current map (which is set up for no vacuum leak )So when you went to Dutch ECU? As I mentioned ping Peter. The only other thing I needed to do after I swapped was drop the plug gap to .75mm to solve stuttering under load. It shouldn't affect starting but hey its £6 from Halfords for the tool and who knows.
Another possibility I guess. I have aftermarket a cams yes.Is this a issue with aftermarket cams ?
I've changed the injectors for a different type (and adjusted map to suit) the old type have been used by many as have the type I changed to, which were brand new. So although I don't know they're atomising, assuming they are being supplied with the correct fuel pressure I would assume all is fine there.Are you sure your injectors are actually atomising the fuel, rather than letting it drip out?
Posted 22 February 2015 - 06:27 PM
Cheers for the tip!If you are having continuous cold start issues, be wary of allowing liquid fuel fall into the cylinders, in time it may thin the oil and cause bore wash. Just sniff the oil and change it regularly until you manage to fix the starting issue. Good luck.
Posted 22 February 2015 - 06:43 PM
Possibly. In my case it was no difference with std head and cams or Saab head and cams. There was an update Peter did for the high lift cams that made drivabilty a low speed much better, no difference in cold start thoughIs this a issue with aftermarket cams ?
Posted 22 February 2015 - 06:48 PM
Yeah, different TB made no difference.I thought I'd looked there, last one I found from you was about using a different throttle body and checking the fuel pressure? Unless I missed one?yeah check out my post about the weird cranking error. Pretty sure you were the first one to post in it
Yep, Vocky also confirmed this as well Its right bloody annoying Mine wasnt as bad as yours though, was always first try but 3-5 seconds of crankingOk, so when I test as long as it hits 3.8psi while priming, cranking and running then all is ok there? Even if it drops back to nothing instantly.Def drops instantly with Walbro on mine. By again no probs when on CS map.
Posted 23 February 2015 - 09:24 AM
When the car has been sat for a while (i.e. when it's stone cold...) perhaps all the fuel is returning to the tank. Ergo when you go to start it, the pump has to pump the fuel all the way through the empty lines. This could be something causing your issue. After it's been sat and fully cooled if you undo the fuel pressure release valve do you get any fuel coming out?
Posted 24 February 2015 - 05:18 PM
